User groups
Re: User groups
Post by aimeos » 22 Feb 2022, 08:18
No, the content of the files.
promptnet
Re: User groups
Post by promptnet » 01 Mar 2022, 10:03
<?php
return [
	'customer' => [
		'manager' => [
			'typo3' => [
				'pid-default' => 171
			'group' => [
				'typo3' => [
Re: User groups
Post by aimeos » 03 Mar 2022, 08:50
If this configuration is in the mshop.php file of the Config directory, this should be OK.
You should also set this in your controller.php config file:
	'frontend' => [
		'customer' => [
			'groupids' => xxx
promptnet
Re: User groups
Post by promptnet » 03 Mar 2022, 10:41
Now, my code in controller.php looks like that:
<?php
return [
	'customer' => [
		'manager' => [
			'typo3' => [
			'group' => [
				'typo3' => [
	'frontend' => [
		'customer' => [
			'groupids' => 48
Unfortunately, it's not working. The admin user still sees all groups in aimeos. Or, is that wanted?
And this is not working, too:
return [
	'customer' => [
		'manager' => [
			'typo3' => [
			'group' => [
				'typo3' => [
			'frontend' => [
				'customer' => [
					'groupids' => 48
Re: User groups
Post by aimeos » 03 Mar 2022, 10:50
There's no way to distinguish groups between sites in TYPO3 because the fe_groups table doesn't have any "siteid" column and doesn't know about multi-tenancy. The only way would be to assign different PIDs to the groups and implement some custom code to map those PIDs to different sites somehow.
