google merchant center - export from aimeos
prosatya
Re: google merchant center - export from aimeos
Post by prosatya » 09 Feb 2020, 14:44
Thank you for update code, Really helpful for me.
Still i want to understand and know relationship so i can have complete knowledge of the product before writing code.
If possible please provide
- Relationship detail Like PK FK CK etc...
- SQL Query so i can easily identify what i want from the table and customize according to idea.
Post by aimeos » 10 Feb 2020, 17:09
Don't mess around with the database tables too much as the Aimeos core abstracts the concrete storage away.
The only thing you should understand is that Aimeos is organized in data domains (product, catalog, service, attribute, text, etc.) and it doesn't have a fixed data structure. Instead, most data (texts/prices/media/attributes) are referenced via the *_list tables so you can add an unlimited number of those references to a product.
If you want to see the database details nevertheless, you should have a look at the definition in phpMyAdmin. Also, you can find the SQL queries used by Aimeos in the config directory: https://github.com/aimeos/aimeos-core/t ... nfig/mshop
prosatya
Post by prosatya » 12 Feb 2020, 09:04
Thank you so much for your quick support.
I review Below two file still not getting what i want (Product and Media Relationship)
https://github.com/aimeos/aimeos-core/b ... /media.php
https://github.com/aimeos/aimeos-core/b ... roduct.php
Here is Simple Example
Let's Suppose my product Id is : 57
1- SELECT * FROM mshop_product where id=57
2- SELECT * FROM mshop_index_text where prodid = 57
3- SELECT * FROM mshop_index_price where prodid = 57
4= SELECT * FROM ??? Media ??? where prodid = 57
What i'm trying to achieve by query
Product URL (shop/detail?ai[d_name]=mshop_product[label])- How i can get this ??
Image URL (URL of main image) - How i can get this ??
Post by aimeos » 13 Feb 2020, 08:45
Don't mess around with SQL queries. Aimeos offers you a powerful API to get all data you need.
Put that into the run() method of your export job controller (https://aimeos.org/docs/Developers/Cont ... controller):
$view = $context->getView();
$manager = \Aimeos\MShop::create( $context, 'product' );
$view->items = $manager->searchItems( $search, ['attribute', 'media', 'price', 'text'] );
$output = $view->render( 'product/export/google-standard' );
and use this template as reference for your own in ./typo3conf/ext/<yourext>/Resources/Private/Extensions/<yourext>/controller/jobs/templates/product/export/google-standard.php (retrieve the items with $this->get( 'items', [] ) in the template):
https://github.com/aimeos/ai-controller ... andard.php
prosatya
Post by prosatya » 13 Feb 2020, 14:04
Again your response is the same as previous. I'm looking for DB Knowledge not building extension,
Now sure why you guys Standard answer " Don't mess around with SQL queries"
Let me know if this is possible what i'm looking.
Thank you.
