Invalid controller "Locale". The controller must implement the TYPO3\CMS\Extbase\Mvc\Controller\ControllerInterface.
hweckhardt
Re: Invalid controller "Locale". The controller must implement the TYPO3\CMS\Extbase\Mvc\Controller\ControllerInterface.
Post by hweckhardt » 22 Sep 2020, 10:10
I have inserted the lines, cleared all caches, deleted typo3temp - unfortunately, the error remains the same.
hweckhardt
Post by hweckhardt » 05 Oct 2020, 17:31
@RenukaSahani:
Could you solve the problem and what was your solution? Many thanks for your help.
Post by aimeos » 06 Oct 2020, 13:39
Thanks to Tobi, the problem has been found and fixed in dev-master:
https://github.com/aimeos/aimeos-typo3/ ... f17e17b76c
hweckhardt
Post by hweckhardt » 06 Oct 2020, 13:57
Unfortunately, when activating the extension, I get this error:
Class 'Aimeos\MShop\Context\Item\Typo3' not found
Many thanks for your ongoing help.
Post by aimeos » 06 Oct 2020, 14:15
Did you install via composer or did you update the TER package with a local checkout?
hweckhardt
Post by hweckhardt » 06 Oct 2020, 14:38
First i made a download of aimeos-typo3-master.zip, unzipped the folder locally, renamed the folder to aimeos and uploaded it to typo3conf/ext. Than i started the backend and tried to activate the extension aimeos, receiving the before mentioned error.
Post by aimeos » 06 Oct 2020, 15:28
That doesn't work. Try this pre-release package instead:
https://aimeos.org/fileadmin/download/a ... 0-pre1.zip
hweckhardt
Post by hweckhardt » 07 Oct 2020, 11:05
Thanks, it works and also the language menu is visible. Perfect!
