Bug with multi mandate and customer account emails from scheduler?
Re: Bug with multi mandate and customer account emails from scheduler?
Post by aimeos » 08 Feb 2021, 09:57
In that case, the links to the products must be also wrong. Is that the case?
georgood
Post by georgood » 08 Feb 2021, 12:21
When the system says "Task failed to execute successfully.", Starting Sheduller with the task ID helps me. For example (task uid=8):
/usr/local/bin/php typo3/sysext/core/bin/typo3 scheduler:run  --task=8
See the source here: https://docs.typo3.org/c/typo3/cms-sche ... Index.html
If you have several tasks in Sheduller, then some of them may work, and some may not, when using: "scheduler: run". It is necessary for each task to have its own line in the system file and script: "scheduler: run --task=8". Then all these tasks will work out.
promptnet
Post by promptnet » 11 Feb 2021, 08:57
No, the first email (order email) is correct. Only the second email (new user account) is wrong.
Tasks execute without problem. No error messages.
promptnet
Post by promptnet » 15 Feb 2021, 14:18
Also, the image in the order email is not displayed. It's an absolute path, and in another instance this works without problems.
Could it be that there are some flaws with multi mandate function?
Post by aimeos » 15 Feb 2021, 14:22
We are not sure where the problem is and it could be either in the TYPO3 routing or Aimeos TYPO3 integration but if it's in the integration, it's not oboius why.
promptnet
Post by promptnet » 16 Feb 2021, 06:54
How can I solve it? Only paid support?
Post by aimeos » 17 Feb 2021, 08:51
Someone has to debug the TYPO3 core code to see what's happening and why TYPO3 generates a wrong URL.
