How to overwrite templates
Shopmister
Re: How to overwrite templates
Post by Shopmister » 08 Mar 2021, 12:54
Did you rename the TYPO3 extension for some reason?
I only integrated the aimeos overwrite templates at the normal path like every typo3 extension, in my own template extension.
Like the path you sayed. Thats the normal Path for overwriting Extensions in typo3.
I did now the Aimeos Extension generator.
Now its working
Can you tell me, why integration in own Extension dosent works? But the Aimeos generated?
Need Aimeos some special file in the Extension that it knows thats the extension to overwrite?
Typoscript from my Own Extenion did work in my own Extension.
Post by aimeos » 09 Mar 2021, 18:08
The generated Aimeos extensions contain required configuration e.g. in ext_localconf.php that is missing in standard TYPO3 extensions.
