Do not display payment and shipping in the checkout process
Re: Do not display payment and shipping in the checkout process
Payment status "authorized" is OK and expected in your case but don't mix up payment status of the order itself and the payment status of the ordered product items displayed in the order detail view of the admin backend.
Can you check if the mshop_order_status table already contains status entries that the e-mails have been sent?
You can also check here in the code if the orders are processed at all:
https://github.com/aimeos/ai-client-htm ... #L116-L124
There is only an entry for stock-update and coupon-update for each order in the table mshop_order_status. Nothing else.
I suspect that the request process is still stuck at the payment verification. At the end of the request, 'You will now be forwarded to our payment provider' still appears. No payment method is active in the shop configuration and delivery and payment are set to no in the "Checks for required services" plugin. If I click continue I get to the confirmation page and the order appears in the Typo3 backend. However, I suspect that the request was not carried out correctly, since the shopping cart is not emptied either.
As long as the payment status is set to "pending", "authorized" or "received", the e-mails should be sent even if there's no payment and delivery service item in the order:
https://github.com/aimeos/ai-client-htm ... andard.php
Are there any errors in the Log panel of the admin backend after you've executed the scheduler task for sending the order confirmation emails?
Yes, there are entrys:
Error while trying to send payment e-mail for order ID "34" and status "5": Parameter "ai__d_name" for route "ai_0" must match "[^/]++" ("<p>product name</p>
Where does the additional "<p>" tags come from? They are causing the problem because I guess.
The p-tag is automatically generated in the text editor (aimeos -> catalog -> products -> sample product -> texts -> name).
Even if I delete the p-tag with the source button in the editor and click on save the p-tag ist generated again.
The <p> tags are inserted by CKEditor 5 but automatically removed before saving:
https://github.com/aimeos/ai-admin-jqad ... #L290-L294
Can you check if you use the latest version and if there's a problem in your setup?
