Neos CMS Flow
Christian
Re: Neos CMS Flow
Post by Christian » 14 Dec 2015, 09:59
Hi again :D
i made composer update this morning and now i get this error:
Template "catalog/lists/body-default.php" not available
Did you changed something?
Re: Neos CMS Flow
Post by aimeos » 14 Dec 2015, 11:44
The dev-master branches are currently under heavy development and may break from time to time.
But the current code should work, at least I've tested it a few minutes ago and I got no error. Your error message looks like the problem we've fixed last week. Did you've installed an older version? The current versions are:
- aimeos/aimeos-core dev-master (f7e0d4d)
- aimeos/ai-flow dev-master (99dfa7a)
- aimeos/aimeos-flow dev-master (8ecb643)
Can you post a stack trace?
Christian
Re: Neos CMS Flow
Post by Christian » 14 Dec 2015, 14:31
aimeos/aimeos-core (dev-master 30084cb => 2015.10.6)
aimeos/ai-flow (dev-master 99dfa7a => 2015.10.2
aimeos/aimeos-flow (1.0.1 => dev-master 8ecb643)
/shop/list
/shop/admin
are fine.
when i insert neos shop plugin in any page over backend:
Then Neos just says to me :
___________________________
An exception was thrown while Neos tried to render your page
page<TYPO3.Neos:Page>/ body<TYPO3.TypoScript:Template>/ content/ main<TYPO3.Neos:PrimaryContent>/ default<TYPO3.TypoScript:Matcher>/ renderer<TYPO3.Neos:ContentCollection>/ content<TYPO3.Neos:ContentCollectionRenderer>/ itemRenderer<TYPO3.Neos:ContentCase>/ default<TYPO3.TypoScript:Matcher>/ element<Aimeos.Shop:Plugin><Aimeos.Shop:Plugin>/
_________________________________
Template "catalog/lists/head-header-default.php" not available
#0 /var/www/sites/paints/neos/Neos-2.0/Packages/Libraries/aimeos/aimeos-core/lib/mwlib/src/MW/View/Standard.php(212): Aimeos\MW\View\Standard->resolve('catalog/lists/h...')
#1 /var/www/sites/paints/neos/Neos-2.0/Packages/Libraries/aimeos/aimeos-core/client/html/src/Client/Html/Catalog/Lists/Head/Standard.php(149): Aimeos\MW\View\Standard->render('catalog/lists/h...')
#2 /var/www/sites/paints/neos/Neos-2.0/Packages/Libraries/aimeos/aimeos-core/client/html/src/Client/Html/Catalog/Lists/Standard.php(242): Aimeos\Client\Html\Catalog\Lists\Head\Standard->getHeader('', Array, NULL)
#3 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/Aimeos_Shop_Controller_AbstractController.php(61): Aimeos\Client\Html\Catalog\Lists\Standard->getHeader()
#4 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/Aimeos_Shop_Controller_CatalogController.php(59): Aimeos\Shop\Controller\AbstractController_Original->getOutput('catalog/lists')
#5 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/Aimeos_Shop_Controller_CatalogController.php(459): Aimeos\Shop\Controller\CatalogController_Original->listComponentAction()
#6 [internal function]: Aimeos\Shop\Controller\CatalogController->listComponentAction()
#7 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/Aimeos_Shop_Controller_CatalogController.php(347): call_user_func_array(Array, Array)
#8 /var/www/sites/paints/neos/Neos-2.0/Packages/Framework/TYPO3.Flow/Classes/TYPO3/Flow/Aop/Advice/AdviceChain.php(59): Aimeos\Shop\Controller\CatalogController->Flow_Aop_Proxy_invokeJoinPoint(Object(TYPO3\Flow\Aop\JoinPoint))
#9 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/TYPO3_Flow_Security_Aspect_PolicyEnforcementAspect.php(66): TYPO3\Flow\Aop\Advice\AdviceChain->proceed(Object(TYPO3\Flow\Aop\JoinPoint))
#10 /var/www/sites/paints/neos/Neos-2.0/Packages/Framework/TYPO3.Flow/Classes/TYPO3/Flow/Aop/Advice/AroundAdvice.php(35): TYPO3\Flow\Security\Aspect\PolicyEnforcementAspect_Original->enforcePolicy(Object(TYPO3\Flow\Aop\JoinPoint))
#11 /var/www/sites/paints/neos/Neos-2.0/Packages/Framework/TYPO3.Flow/Classes/TYPO3/Flow/Aop/Advice/AdviceChain.php(57): TYPO3\Flow\Aop\Advice\AroundAdvice->invoke(Object(TYPO3\Flow\Aop\JoinPoint))
#12 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/Aimeos_Shop_Controller_CatalogController.php(471): TYPO3\Flow\Aop\Advice\AdviceChain->proceed(Object(TYPO3\Flow\Aop\JoinPoint))
#13 [internal function]: Aimeos\Shop\Controller\CatalogController->listComponentAction()
#14 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/TYPO3_Flow_Mvc_Controller_ActionController.php(419): call_user_func_array(Array, Array)
#15 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/TYPO3_Flow_Mvc_Controller_ActionController.php(177): TYPO3\Flow\Mvc\Controller\ActionController_Original->callActionMethod()
#16 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/TYPO3_Flow_Mvc_Dispatcher.php(154): TYPO3\Flow\Mvc\Controller\ActionController_Original->processRequest(Object(TYPO3\Flow\Mvc\ActionRequest), Object(TYPO3\Flow\Http\Response))
#17 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/TYPO3_Flow_Mvc_Dispatcher.php(107): TYPO3\Flow\Mvc\Dispatcher_Original->initiateDispatchLoop(Object(TYPO3\Flow\Mvc\ActionRequest), Object(TYPO3\Flow\Http\Response))
#18 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/TYPO3_Neos_TypoScript_PluginViewImplementation.php(125): TYPO3\Flow\Mvc\Dispatcher_Original->dispatch(Object(TYPO3\Flow\Mvc\ActionRequest), Object(TYPO3\Flow\Http\Response))
#19 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/TYPO3_TypoScript_Core_Runtime.php(442): TYPO3\Neos\TypoScript\PluginViewImplementation_Original->evaluate()
#20 /var/www/sites/paints/neos/Neos-2.0/Data/Temporary/Development/Cache/Code/Flow_Object_Classes/TYPO3_TypoScript_Core_Runtime.php(227): TYPO3\TypoScript\Core\Runtime_Original->evaluateInternal('page
Re: Neos CMS Flow
Post by aimeos » 15 Dec 2015, 12:45
Christian wrote:aimeos/aimeos-core (dev-master 30084cb => 2015.10.6)
These versions doesn't play together. Either you need the dev-master or 1.x/2015.10.x for all Aimeos packages.
If you want to setup a shop with Aimeos we recommend using 1.x, for contributions dev-master is the right choice (but dev-master may break from time to time).
Christian
Re: Neos CMS Flow
Post by Christian » 15 Dec 2015, 13:59
Ok thanks. I wonder why composer installs 1.0 version. In composer.json i said dev-master. anyway i will test a little bit more.
Re: Neos CMS Flow
Post by aimeos » 16 Dec 2015, 09:54
That's strange, indeed! Composer has updated aimeos-core and ai-flow to 2015.10.x versions first and then aimeos-flow to dev-master instead of leaving aimeos-core and ai-flow at the dev-master branch.
Christian
Re: Neos CMS Flow
Post by Christian » 17 Dec 2015, 09:33
Version 1.0 is running perfektly. If i insert the Pluginviews, is there any way to rewrite the Urls? Did i forgot something?
And the first view is without styles as expected. If i click on the article there are styles from default theme again. i think this should be also shown without styles?
Re: Neos CMS Flow
Post by aimeos » 17 Dec 2015, 14:45
Christian wrote:Version 1.0 is running perfektly. If i insert the Pluginviews, is there any way to rewrite the Urls? Did i forgot something?
In Flow you can add routes in the Routes.yaml file but I don't know how this works in Neos. We've found no documentation about this and the answer from the Neos developer wasn't helpful either.
Christian wrote:And the first view is without styles as expected. If i click on the article there are styles from default theme again. i think this should be also shown without styles?
I think that's exactly the problem. First you see the component you've placed on the page and after the click it displays the Aimeos detail page for Flow. Instead, the components needs the configuration where the detail component is placed so your browser loads that page.
Christian
Re: Neos CMS Flow
Post by Christian » 17 Dec 2015, 14:55
Ok i will continue trying. If i found any solution i will let you know.
Christian
Re: Neos CMS Flow
Post by Christian » 07 Jan 2016, 10:09
I think the solution would be to add only one "new" view for neos wich open first the list view like this url:
?--aimeos_shop-plugin%5B%40package%5D=aimeos.shop&--aimeos_shop-plugin%5B%40controller%5D=catalog&--aimeos_shop-plugin%5B%40action%5D=list&--aimeos_shop-plugin%5Bd_prodid%5D=1&--aimeos_shop-plugin%5Bd_name%5D=Demo_article&--aimeos_shop-plugin%5Bl_pos%5D=1&--aimeos_shop-plugin%5B%40format%5D=html
you have to remove html and body tag as well and add the css and js in header from neos. so the main menu from neos will be integrated and the styles from aimeos theme will be recognized also. every click will open the same styles now. Maybe you dont add any style so it depends on the Site Package.
i would remove every other view like checkout, history, basket, and so on. so the handling will be managed be the aimeos package.
