Cannot add to basket after upgrade
promptnet
Re: Cannot add to basket after upgrade
Post by promptnet » 12 Dec 2024, 13:31
Browser console is empty.
promptnet
Post by promptnet » 12 Dec 2024, 15:31
What else can I do to find the bug?
Post by aimeos » 12 Dec 2024, 16:52
You can try to remove lines from this template until something is shown again:
https://github.com/aimeos/ai-admin-jqad ... tegory.php
Maybe it's a problem in a sub-panel before so you should check which sub-panels work at all.
promptnet
Post by promptnet » 13 Dec 2024, 06:40
$this->get( 'categoryTypes', [] )
is empty:
object(Aimeos\Map)#49894 (2) { ["list":protected]=> array(0) { } ["sep":protected]=> string(1) "/" }
Post by aimeos » 13 Dec 2024, 09:32
Please check your mshop_product_list_type table for records with domain "catalog".
promptnet
Post by promptnet » 16 Dec 2024, 13:44
These are the rows:
INSERT INTO `mshop_product_list_type` (`id`, `siteid`, `domain`, `code`, `label`, `pos`, `status`, `mtime`, `ctime`, `editor`, `i18n`) VALUES
(526, '63.', 'catalog', 'default', 'Standard', 0, 1, '2024-12-11 15:10:17', '2024-12-11 15:10:17', 'core', '{}'),
(527, '63.', 'catalog', 'promotion', 'Promotion', 0, 1, '2024-12-11 15:10:17', '2024-12-11 15:10:17', 'core', '{}');
Post by aimeos » 16 Dec 2024, 13:45
Also for the correct site ID?
promptnet
Post by promptnet » 16 Dec 2024, 14:18
Hm, you're right!
After the upgrde I obviously re-created the site with a wrong term. Thus, a new site was generated.
Thanks for your help!
