Varius Problems
Re: Varius Problems
Post by aimeos » 28 Dec 2016, 19:14
Metalics wrote:This problem still exist. Im not sure if the problem is caused by "force-search", but when u are in a category, Attribute Filter doesn't respect the current catalog and it filters for whole products in the webshop.
We can't confirm any problem in our standard setup. The "force-search" setting adds the "f_catid" parameter to the POST request, so the current category is part of the search. Also the attribute filter works as expected when using the "force-search" configuration. Did you overwrite the catalog filter tree template and removed the "force-search" code?
