sitemap product url
27bit.ru
Re: sitemap product url
Post by 27bit.ru » 06 Apr 2017, 16:38
aimeos wrote:Which Aimeos version are you currently using?
16.10.5-pre1
Post by aimeos » 06 Apr 2017, 20:55
Does the 16.10.4 version from TER work better?
27bit.ru
Post by 27bit.ru » 07 Apr 2017, 08:39
aimeos wrote:Does the 16.10.4 version from TER work better?
I do not understand you a little, but I installed version 16.10.4 of TER, and on it your version is 16.10.5. Anyway, the errors remained.
Is it possible to install the version 17.3.0 to 16.10.4?
I hope this can solve the problems.
Post by aimeos » 08 Apr 2017, 00:56
Does both problems still occur with Aimeos 16.10.4?
If yes, which TYPO3 version are you currently using? TYPO3 7.6.16?
27bit.ru
Post by 27bit.ru » 08 Apr 2017, 14:05
aimeos wrote:Does both problems still occur with Aimeos 16.10.4?
All problems remain, those that I wrote above.
Yes My version of typo3 7.6.16
Post by aimeos » 08 Apr 2017, 14:14
Does the scheduler problem goes away if you use TYPO3 7.6.15?
27bit.ru
Post by 27bit.ru » 08 Apr 2017, 16:35
aimeos wrote:Does the scheduler problem goes away if you use TYPO3 7.6.15?
I don `t know, I need to install 7.6.15 again to check?
Post by aimeos » 09 Apr 2017, 17:20
You can simply extract the previous version in your document root and change the links to "typo3_src"
27bit.ru
Post by 27bit.ru » 11 Apr 2017, 14:13
aimeos wrote:You can simply extract the previous version in your document root and change the links to "typo3_src"
The planner eliminated the error. When I create a sitemap I get a link (example)
http://new.site.ru?id=13&ai%5Bcontroller%5D=catalog&ai%5Baction%5D=detail&ai%5Ba-name%5D=%D0%9A%D0%BE%D1%84%D0%B5%D0%B2%D0%B0%D1%80%D0%BA%D0%B0-Vigor-HX-2115&ai%5Bd-product-id%5D=1
But, if you go to the generated link, then the product page does not go over, and writes an error to frontend
No product with ID "" found
to madminlog
#0 /home/virtwww/w_new-site/http/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/client/html/src/Client/Html/Catalog/Detail/Standard.php(501): Aimeos\Client\Html\Catalog\Detail\Standard->getProductItem(NULL, Array)
#1 /home/virtwww/w_new-site/http/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/client/html/src/Client/Html/Catalog/Detail/Standard.php(295): Aimeos\Client\Html\Catalog\Detail\Standard->setViewParams(Object(Aimeos\MW\View\Standard), Array, NULL)
#2 /home/virtwww/w_new-site/http/typo3conf/ext/aimeos/Classes/Controller/AbstractController.php(141): Aimeos\Client\Html\Catalog\Detail\Standard->getHeader()
#3 /home/virtwww/w_new-site/http/typo3conf/ext/aimeos/Classes/Controller/CatalogController.php(112): Aimeos\Aimeos\Controller\AbstractController->getClientOutput(Object(Aimeos\Client\Html\Catalog\Detail\Standard))
#4 [internal function]: Aimeos\Aimeos\Controller\CatalogController->detailAction()
#5 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Mvc/Controller/ActionController.php(283): call_user_func_array(Array, Array)
#6 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Mvc/Controller/ActionController.php(176): TYPO3\CMS\Extbase\Mvc\Controller\ActionController->callActionMethod()
#7 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Mvc/Dispatcher.php(86): TYPO3\CMS\Extbase\Mvc\Controller\ActionController->processRequest(Object(TYPO3\CMS\Extbase\Mvc\Web\Request), Object(TYPO3\CMS\Extbase\Mvc\Web\Response))
#8 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Mvc/Web/FrontendRequestHandler.php(69): TYPO3\CMS\Extbase\Mvc\Dispatcher->dispatch(Object(TYPO3\CMS\Extbase\Mvc\Web\Request), Object(TYPO3\CMS\Extbase\Mvc\Web\Response))
#9 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Core/Bootstrap.php(206): TYPO3\CMS\Extbase\Mvc\Web\FrontendRequestHandler->handleRequest()
#10 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Core/Bootstrap.php(193): TYPO3\CMS\Extbase\Core\Bootstrap->handleRequest()
#11 [internal function]: TYPO3\CMS\Extbase\Core\Bootstrap->run('', Array)
#12 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/ContentObject/ContentObjectRenderer.php(7311): call_user_func_array(Array, Array)
#13 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/ContentObject/UserContentObject.php(40): TYPO3\CMS\Frontend\ContentObject\ContentObjectRenderer->callUserFunction('TYPO3\\CMS\\Extba...', Array, '')
#14 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/ContentObject/ContentObjectRenderer.php(943): TYPO3\CMS\Frontend\ContentObject\UserContentObject->render(Array)
#15 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/ContentObject/ContentObjectRenderer.php(859): TYPO3\CMS\Frontend\ContentObject\ContentObjectRenderer->render(Object(TYPO3\CMS\Frontend\ContentObject\UserContentObject), Array)
#16 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Controller/TypoScriptFrontendController.php(3577): TYPO3\CMS\Frontend\ContentObject\ContentObjectRenderer->cObjGetSingle('USER', Array)
#17 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Controller/TypoScriptFrontendController.php(3522): TYPO3\CMS\Frontend\Controller\TypoScriptFrontendController->INTincScript_process(Array)
#18 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Controller/TypoScriptFrontendController.php(3488): TYPO3\CMS\Frontend\Controller\TypoScriptFrontendController->recursivelyReplaceIntPlaceholdersInContent()
#19 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Http/RequestHandler.php(232): TYPO3\CMS\Frontend\Controller\TypoScriptFrontendController->INTincScript()
#20 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/core/Classes/Core/Bootstrap.php(302): TYPO3\CMS\Frontend\Http\RequestHandler->handleRequest(Object(TYPO3\CMS\Core\Http\ServerRequest))
#21 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Http/Application.php(78): TYPO3\CMS\Core\Core\Bootstrap->handleRequest(Object(TYPO3\CMS\Core\Http\ServerRequest))
#22 /home/virtwww/w_new-site/http/typo3_src-7.6.16/index.php(33): TYPO3\CMS\Frontend\Http\Application->run()
#23 [internal function]: {closure}()
#24 /home/virtwww/w_new-site/http/typo3_src-7.6.16/index.php(34): call_user_func(Object(Closure))
#25 {main}
Post by aimeos » 20 Apr 2017, 15:47
We've backported the whole scheduler/URL stuff from the new 17.4.0 release because it's the only implementation that works with TYPO3 7.6.16, 8.7.x and Realurl from the command line. Can you please test it in your environment?
https://aimeos.org/fileadmin/download/a ... 5-pre2.zip
