boettner
Post by boettner » 17 Nov 2022, 06:31
Thanks once again I didn´t recognize the obvious... :roll:
Moritz
Post by Moritz » 17 Nov 2022, 11:38
Moritz wrote: 27 Oct 2022, 11:08
Seems like the still existing typeid constraint makes problems.
Does it work if you remove it?
Then it works.
Will it become part of the upgrade wizard?
With the installation of v22.10.3-pre2 the fk_t3feuli_typeid constraint is still exists and the download problem occurs again.
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Post by aimeos » 18 Nov 2022, 05:20
It never worked because the name of the fe_user_* tables was wrong. This pre-release should fix the problem now:
https://aimeos.org/fileadmin/download/a ... 4-pre1.zip
Moritz
Post by Moritz » 18 Nov 2022, 11:43
Thank you!
With this fix the download works again 👍
PHP 8.2.24
Typo3 v12.4.23 LTS
