Property-Based SKU
Re: Property-Based SKU
Post by aimeos » 25 Jun 2019, 15:44
Please keep in mind that the theme files are not taken from
typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/client/html/themes/aimeos.js
but instead from
typo3conf/ext/aimeos/Resources/Public/Themes/aimeos.js
superscotty19
Post by superscotty19 » 25 Jun 2019, 20:45
Oh! Good to know!
In that case, I have changed the .js file (keeping the .php file as-is), and now I get nothing in the properties dropdown at all. Now, typo/typo3conf/ext/aimeos/Resources/Public/Themes/aimeos.js looks like this:
                                        } else {
                                                $(".addbasket .btn-action", parent).removeClass("btn-disabled").removeAttr("disabled");
                                        # added to fix glitch found by Scott and fixed by Aimeos :-)
                                        $(".catalog-detail-additional .subproduct-actual").removeClass("subproduct-actual");
                                        $(".catalog-detail-additional .subproduct-" + prodId).addClass("subproduct-actual");
# Removed as part of a glitch found by Scott and fixed by Aimeos :-)
#                       $(".catalog-detail-additional .subproduct-actual").removeClass("subproduct-actual");
#                       $(".catalog-detail-additional .subproduct-" + prodId).addClass("subproduct-actual");
-S.
Post by aimeos » 26 Jun 2019, 10:33
We've created a pre-release for you so you don't have to patch around yourself:
https://aimeos.org/fileadmin/download/a ... 0-pre1.zip
superscotty19
Post by superscotty19 » 26 Jun 2019, 22:48
THAT WORKED!!!!
Thank you!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
-Scott.
