[Solved - Again v21.7] - [Solved in 21.4] - zeynepjs mobile-first navigation menu
Re: [Solved - Again v21.7] - [Solved in 21.4] - zeynepjs mobile-first navigation menu
Post by aimeos » 22 Nov 2021, 11:42
OK, problem understood.
We've optimized loading of categories to avoid loading the complete category tree which may not be displayed afterwards. To activate displaying two or more levels of categories all the times, you have to add the number of levels in the flexform of the catalog/filter or catalog/tree plugin (whatever you are using) in the field for "Always display these category levels"
ivanp
Post by ivanp » 22 Nov 2021, 12:01
Ahhh, my bad, I totally forgot about setting the number of levels.
Thank you!!!
