We've added debug logging for delete/insert/update statements executed during the migration in this pre-release:
https://aimeos.org/fileadmin/download/a ... 3-pre4.zip
With this prerelease you removed the string parsing in Aimeos\MShop\Order\Item\Standard so the type error with the relatedId come up again.
Where can I find the log?
Edit: Ah I get the output in the Upgrade Wizard. I only installed the prerelease.
I will take a look at it tomorrow.
Are the customers are loaded from fe_users or fe_users_list?
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Typo3 v12.4.23 LTS
Next pre-release with the changes from pre3:
https://aimeos.org/fileadmin/download/a ... 3-pre5.zip
Customers are from fe_users, the fe_users_list is only for assigning relations to customer records.
I think I found the problem.
In the fe_users table there is a column "siteId".
For many users the value is set to "1", for the rest it's empty.
Only the users with an empty value in this column are displayed.
When I set the value to an empty string for a missing user, it is shown up in the list again.
Is this a bug or a wrong configuration in my system?
PHP 8.2.24
Typo3 v12.4.23 LTS
Typo3 v12.4.23 LTS
The values in the siteid columns must be changed from e.g. "1" to "1." to work properly in the newer Aimeos versions.
There was a problem in the migration. Can you please try this package:
https://aimeos.org/fileadmin/download/a ... 3-pre6.zip
Only installing the package does not solve the problem.
Should I manually change the siteId of the fe_users table?
PHP 8.2.24
Typo3 v12.4.23 LTS
Typo3 v12.4.23 LTS
You have to run the upgrade wizard again to migrate the site IDs in the fe_users table.
The IDs have not changed after executting the upgrade wizard.
PHP 8.2.24
Typo3 v12.4.23 LTS
Typo3 v12.4.23 LTS
Can you please check why the site IDs are not migrated here?
- https://github.com/aimeos/ai-typo3/blob ... dTypo3.php
- https://github.com/aimeos/aimeos-core/b ... #L112-L149
I think here https://github.com/aimeos/ai-typo3/blob ... o3.php#L49 the second condition should be negated?
The function never comes to the UPDATE part.
PHP 8.2.24
Typo3 v12.4.23 LTS
Typo3 v12.4.23 LTS
