postage porto
marksyl
Re: postage porto
Post by marksyl » 10 Dec 2015, 11:34
hello!
thanx for your answer...
at the source-code i see:
<label for="address-billing-city">Ort		</label><input type="text" id="address-billing-city" name="ai[ca_billing][order.base.address.city]" value="" placeholder="Ort" disabled="disabled" />
it is disabled...
but i have no configuration
"No service for code "" found" wird darunter angezeigt
if it would working, this code (in tsconfig in checkout-site) would affects, that this are my formular-fields and you have to fill?
plugin.tx_aimeos.settings.client.html.common.standard.address.billing.mandatory {
0 = order.base.address.salutation
1 = order.base.address.firstname
2 = order.base.address.lastname
3 = order.base.address.address1
4 = order.base.address.postal
5 = order.base.address.city
6 = order.base.address.email
lg marksyl
Re: postage porto
Post by aimeos » 10 Dec 2015, 11:46
Please use plugin.tx_aimeos.settings.client.html.checkout.standard.address.billing.mandatory instead as it replaced the config setting you've noted:
https://aimeos.org/docs/Configuration/C ... /mandatory
marksyl
Re: postage porto
Post by marksyl » 10 Dec 2015, 12:01
hi
thanx for this...
okay, that is the 2nd step for me...
the first is, it doesn't work...
it is disabled, i can see at the code...
but i have done no special configuration
"No service for code "" found" is shown on the same site under the formular
lg, marksyl
Re: postage porto
Post by aimeos » 12 Dec 2015, 12:07
Problems have been solved. There was still a wrong TypoScript in the TypoScript field of the plugin flexform. Furthermore, the checkout update plugin was placed below the checkout standard plugin which shouldn't be there and it produced the "No service for code "" found" error.
