sitemap product url
Kai
Re: sitemap product url
Post by Kai » 20 Apr 2017, 16:35
Hey!
Is there a general problem with the TYPO3-Scheduler-Task?
We are using TYPO3 7.6.15 and aimeos 17.3. If we run a scheduler task by hand (clicking on the button in backend) it works fine. When the sheduler task is started by cli_dispatch.phpsh it doesn't work.
Best regards!
Kai
Post by aimeos » 21 Apr 2017, 16:13
The TYPO3 ObjectManager returns an incomplete UriBuilder object when called from the command line. Therefore, Aimeos has to build the object itself: https://github.com/aimeos/aimeos-typo3/ ... se.php#L93
We will use the same code in the next 16.10.5 version as well to support nice URLs in e-mails too.
27bit.ru
Post by 27bit.ru » 23 Apr 2017, 13:54
aimeos wrote:We've backported the whole scheduler/URL stuff from the new 17.4.0 release because it's the only implementation that works with TYPO3 7.6.16, 8.7.x and Realurl from the command line. Can you please test it in your environment?
https://aimeos.org/fileadmin/download/a ... 5-pre2.zip
Yes, I installed pre2. But when I try to start the task of creating a sitemap in the scheduler, I get the error "No domain record in root page"
my typoconfig
config.baseURL = http://new.site.ru
Post by aimeos » 24 Apr 2017, 10:33
You need a domain record entry in your TYPO3 root page so absolute URLs can be created. The baseURL setting has no effect in this case as it's only used for the <base> tag in the HTML head section.
27bit.ru
Post by 27bit.ru » 24 Apr 2017, 14:44
27bit.ru wrote:
aimeos wrote:You can simply extract the previous version in your document root and change the links to "typo3_src"
The planner eliminated the error. When I create a sitemap I get a link (example)
http://new.site.ru?id=13&ai%5Bcontroller%5D=catalog&ai%5Baction%5D=detail&ai%5Ba-name%5D=%D0%9A%D0%BE%D1%84%D0%B5%D0%B2%D0%B0%D1%80%D0%BA%D0%B0-Vigor-HX-2115&ai%5Bd-product-id%5D=1
But, if you go to the generated link, then the product page does not go over, and writes an error to frontend
No product with ID "" found
to madminlog
#0 /home/virtwww/w_new-site/http/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/client/html/src/Client/Html/Catalog/Detail/Standard.php(501): Aimeos\Client\Html\Catalog\Detail\Standard->getProductItem(NULL, Array)
#1 /home/virtwww/w_new-site/http/typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/client/html/src/Client/Html/Catalog/Detail/Standard.php(295): Aimeos\Client\Html\Catalog\Detail\Standard->setViewParams(Object(Aimeos\MW\View\Standard), Array, NULL)
#2 /home/virtwww/w_new-site/http/typo3conf/ext/aimeos/Classes/Controller/AbstractController.php(141): Aimeos\Client\Html\Catalog\Detail\Standard->getHeader()
#3 /home/virtwww/w_new-site/http/typo3conf/ext/aimeos/Classes/Controller/CatalogController.php(112): Aimeos\Aimeos\Controller\AbstractController->getClientOutput(Object(Aimeos\Client\Html\Catalog\Detail\Standard))
#4 [internal function]: Aimeos\Aimeos\Controller\CatalogController->detailAction()
#5 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Mvc/Controller/ActionController.php(283): call_user_func_array(Array, Array)
#6 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Mvc/Controller/ActionController.php(176): TYPO3\CMS\Extbase\Mvc\Controller\ActionController->callActionMethod()
#7 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Mvc/Dispatcher.php(86): TYPO3\CMS\Extbase\Mvc\Controller\ActionController->processRequest(Object(TYPO3\CMS\Extbase\Mvc\Web\Request), Object(TYPO3\CMS\Extbase\Mvc\Web\Response))
#8 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Mvc/Web/FrontendRequestHandler.php(69): TYPO3\CMS\Extbase\Mvc\Dispatcher->dispatch(Object(TYPO3\CMS\Extbase\Mvc\Web\Request), Object(TYPO3\CMS\Extbase\Mvc\Web\Response))
#9 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Core/Bootstrap.php(206): TYPO3\CMS\Extbase\Mvc\Web\FrontendRequestHandler->handleRequest()
#10 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/extbase/Classes/Core/Bootstrap.php(193): TYPO3\CMS\Extbase\Core\Bootstrap->handleRequest()
#11 [internal function]: TYPO3\CMS\Extbase\Core\Bootstrap->run('', Array)
#12 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/ContentObject/ContentObjectRenderer.php(7311): call_user_func_array(Array, Array)
#13 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/ContentObject/UserContentObject.php(40): TYPO3\CMS\Frontend\ContentObject\ContentObjectRenderer->callUserFunction('TYPO3\\CMS\\Extba...', Array, '')
#14 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/ContentObject/ContentObjectRenderer.php(943): TYPO3\CMS\Frontend\ContentObject\UserContentObject->render(Array)
#15 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/ContentObject/ContentObjectRenderer.php(859): TYPO3\CMS\Frontend\ContentObject\ContentObjectRenderer->render(Object(TYPO3\CMS\Frontend\ContentObject\UserContentObject), Array)
#16 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Controller/TypoScriptFrontendController.php(3577): TYPO3\CMS\Frontend\ContentObject\ContentObjectRenderer->cObjGetSingle('USER', Array)
#17 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Controller/TypoScriptFrontendController.php(3522): TYPO3\CMS\Frontend\Controller\TypoScriptFrontendController->INTincScript_process(Array)
#18 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Controller/TypoScriptFrontendController.php(3488): TYPO3\CMS\Frontend\Controller\TypoScriptFrontendController->recursivelyReplaceIntPlaceholdersInContent()
#19 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Http/RequestHandler.php(232): TYPO3\CMS\Frontend\Controller\TypoScriptFrontendController->INTincScript()
#20 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/core/Classes/Core/Bootstrap.php(302): TYPO3\CMS\Frontend\Http\RequestHandler->handleRequest(Object(TYPO3\CMS\Core\Http\ServerRequest))
#21 /home/virtwww/w_new-site/http/typo3_src-7.6.16/typo3/sysext/frontend/Classes/Http/Application.php(78): TYPO3\CMS\Core\Core\Bootstrap->handleRequest(Object(TYPO3\CMS\Core\Http\ServerRequest))
#22 /home/virtwww/w_new-site/http/typo3_src-7.6.16/index.php(33): TYPO3\CMS\Frontend\Http\Application->run()
#23 [internal function]: {closure}()
#24 /home/virtwww/w_new-site/http/typo3_src-7.6.16/index.php(34): call_user_func(Object(Closure))
#25 {main}
Nothing has changed, everything has remained the same.
Post by aimeos » 25 Apr 2017, 11:33
For some reason the patch was not included in the package. Please try this one instead:
https://aimeos.org/fileadmin/download/a ... 5-pre3.zip
27bit.ru
Post by 27bit.ru » 25 Apr 2017, 14:10
aimeos wrote:For some reason the patch was not included in the package. Please try this one instead:
Post by aimeos » 25 Apr 2017, 22:19
We've found out that the code for generating the sitemap was OK but existing sitemap files were not overwritten. This is fixed now:
https://aimeos.org/fileadmin/download/a ... 5-pre4.zip
27bit.ru
Post by 27bit.ru » 26 Apr 2017, 04:38
aimeos wrote:We've found out that the code for generating the sitemap was OK but existing sitemap files were not overwritten. This is fixed now:
url
http://new.site.ru?id=13&ai%5Bcontroller%5D=catalog&ai%5Baction%5D=detail&ai%5Bd_name%5D=%D0%9A%D0%BE%D1%84%D0%B5%D0%B2%D0%B0%D1%80%D0%BA%D0%B0_Vigor_HX-2115&ai%5Bd_prodid%5D=1
aimeos log
#25 {main}
Post by aimeos » 26 Apr 2017, 08:18
URLs in sitemaps are escaped (& -> &) which you have to revert first before you can open the URL in your browser:
http://new.site.ru?id=13&ai%5Bcontrolle ... rodid%5D=1
