Separate mails for shop owner and customer - no bcc
boettner
Re: Separate mails for shop owner and customer - no bcc
Post by boettner » 06 Aug 2020, 13:20
Hm, in my case at least I can find all my custom classes there.
From where did you set up your own aimeos extension. From the skeleton offered here https://aimeos.org/extensions/ via the "Create own extension" button?
daniel
Post by daniel » 06 Aug 2020, 13:42
no, i have an extension for other things and put the aimeos stuff there...
boettner
Post by boettner » 06 Aug 2020, 13:46
So please create one via the builder and compare everything to your implementation. Be sure to select the TYPO3 v10 variant.
boettner
Post by boettner » 06 Aug 2020, 13:49
daniel
Post by daniel » 06 Aug 2020, 13:51
ok, i will check this.
daniel
Post by daniel » 06 Aug 2020, 14:35
i created a new typo3 extension (https://aimeos.org/extensions/ > TYPO3 2020.x extension) , put all my shop changes (templates, Email Decorator etc.) in this extension. Shop works fine, but in autoload_classmap.php my class is still not present... I think in my previous extension everything was ok...
the classes path for classes in autoload is i think "Classes", like in composer.json set (i add the autoload part in ext_emconf.php because i do not use composer).
So i do not have an Classes folder in my ext, in the autoload_psr4.php file is the entry:
'Aimeos\\Aimeos\\' => array($typo3InstallDir . 'typo3conf/ext/mynewext/Classes'),
Do i have to generate a class file in folder "Classes"?
Sorry, i'm not a backend developer... I really appreciate your help! thanks a lot
boettner
Post by boettner » 07 Aug 2020, 07:59
No worries, I hope I am able to help you.
The loading order is also relevant. Be sure to include your extension, meaning the TypoScript template, at the last position.
If your classes don´t load even after dumping the autoload definition and clearing caches uninstalling and reinstalling sometimes helps. See here the background information on the TYPO3 class loading mechanism:
https://docs.typo3.org/m/typo3/referenc ... Index.html
daniel
Post by daniel » 10 Aug 2020, 08:06
Hi, thanks, but why are the other decorator-classes are also not in the autoload? and they are working, i made a test adding a decorator class which is per default in the shop...
boettner
Post by boettner » 10 Aug 2020, 14:27
I can´t really say why. In my setup all classes get referenced. Did you compare the composer.json in your custom extension to the skeleton of the Aimeos extension builder?
daniel
Post by daniel » 10 Aug 2020, 14:33
Hi, i do not use composer...
Is it possible to overwrite the files "typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/controller/jobs/src/Controller/Jobs/Order/Email/Payment/Standard.php" and "typo3conf/ext/aimeos/Resources/Private/Extensions/ai-client-html/client/html/src/Client/Html/Email/Payment/Standard.php"
If possible i can implement my email there...
