Product variants displayed in list
karin.seifert
Post by karin.seifert » 30 May 2017, 09:19
Hi!
I made a product of type "Selection" and then added various products of type "Article", which only differ in size and price. This works fine, but all the variants are also displayed in the catalog list as extra products.
TYPO3 8.7.1
Suse Tumbelweed / CENTOS7
PHP 7.1
AImeos 17.4.1
Realurl uninstalled, but it didn't make any difference.
Regards,
Karin
Re: Product variants displayed in list
Post by aimeos » 30 May 2017, 20:26
You have associated the articles to a category, then they are shown in the lists
karin.seifert
Post by karin.seifert » 31 May 2017, 06:16
Thanks!
That solved the problem.
I'm just beginning with Aimeos, and although not every possibility of the configuration is described in the documentation, I appreciate this elaborate shop system.
So thanks for the quick answer and thanks a lot for to whole development team.
Post by aimeos » 31 May 2017, 09:27
We are glad you like Aimeos and would be grateful if you can share your knowledge with others in the future :-)
