Easy way to disable features of the plugin
t_csaba
Post by t_csaba » 13 Oct 2017, 09:15
Hi, I would like to disable the payment and delivery and coupon options. According to the documentation i have changed the steps with the configuration:
*plugin.tx_aimeos.settings.client.html.checkout.standard.standard.subparts{...}
So now the payment and delivery do not appear, but in the summary section, i get the error message:
*Service of type "payment" not available
In the backend i have disbled the plugins linked to payment and delivery, and disabled the services too. Is there a simple way to disable these features that i missed in the documentation?
typo3 8.7.7
php 7.0.16
Linux 2.6
Re: Easy way to disable features of the plugin
Post by aimeos » 14 Oct 2017, 17:23
Placing orders without delivery and payment services only works in the latest dev-master version. Before, you need at least a payment service (PostPay for example) and you have to to adapt the checkout summary template yourself.
t_csaba
Post by t_csaba » 04 Jan 2018, 15:08
HI again, i have version 17.10.1, but still when i checkout this error appears:
Processing the payment failed
Is there anything that I've missed?
t_csaba
Post by t_csaba » 04 Jan 2018, 15:17
this is the typoscript config:
0 = address
1 = summary
3 = process
Post by aimeos » 04 Jan 2018, 21:45
dev-master means the upcoming 2018.01 version. In 2017.10, you can add a default delivery/payment service (Autofill plugin) and hide that via CSS in the checkout process.
t_csaba
Post by t_csaba » 05 Jan 2018, 08:54
Thank you for the reply, it works perfectly.
