Configuring Moduls access for Redactors
mantik
Post by mantik » 09 Nov 2017, 17:36
how can i configure the available moduls for usergroups or redactors.
For example i wanna disable the Language or Expertmodul from the admin (they dont have to apear in the sidebar-menu).
Re: Configuring Moduls access for Redactors
Post by aimeos » 09 Nov 2017, 20:41
Here you can see the configuration for the sidebar navigation including the permissions:
https://github.com/aimeos/ai-admin-jqad ... /admin.php
You can change both via TypoScript and you need TYPO3 backend user groups named like the groups in the config to restrict the panels to certain user groups. You can even create more user groups (e.g. limited editor, dashboard viewer) and configure them the same way.
Post by aimeos » 09 Nov 2017, 20:45
You can find additional configuration like the list of shown columns for each panel here:
https://aimeos.org/docs/Configuration/Core/admin/jqadm
mantik
Post by mantik » 29 Nov 2017, 13:21
im sorry i dont get it.
i've now do that:
   plugin.tx_aimeos.settings.admin.jqadm {
        resource{
            dashboard {
                groups = Shop
i've a typo3-BE-grop with the name Shop.
when i loigin then i got: Not allowed to access JQAdm "dashboard" client
Post by aimeos » 29 Nov 2017, 23:52
The permitted groups have to be a list of entries and the TYPO3 configuration of plugins for the backend starts with "module":
   module.tx_aimeos.settings.admin.jqadm {
        resource {
            dashboard {
                groups {
                    0 = Shop
mantik
Post by mantik » 30 Nov 2017, 13:08
still the same message.
is this in he extension typoscript or in ts config?
Post by aimeos » 01 Dec 2017, 10:25
It's in the Web -> Template -> Root page -> Info/Modify -> Setup TypoScript but you can also move it to a file so it can be versioned.
The full config for allowing a user from the "admin" and "Shop" group to access the dashboard is:
module.tx_aimeos.settings.admin {
    jqadm {
        resource {
            dashboard {
                groups {
                    0 = admin
                    1 = Shop
    jsonadm {
        resource {
            locale {
                currency {
                    groups {
                        0 = admin
                        1 = Shop
            order {
                groups {
                    0 = admin
                    1 = Shop
mantik
Post by mantik » 05 Dec 2017, 11:18
After i put my extension template on typo3 root it works.
thnx
