How to see the attibutes names in the fromtend
chricken
Post by chricken » 20 Nov 2017, 05:19
I have added some attributes and attibute types to my products.
They are shown in the frontend under the tab 'Eigenschaften', which is perfect.
But I see the key of the attribute type instead of the value, which is surprising.
I couldn't find any translation files or stuff, so I am asking here:
How can I view the values of my attribute types in the frontend?
I am using Aimeos 17.10.2pre1 under Typo3 8.7.8 with PHP 7.0.20.
Regards
Christian
Re: How to see the attibutes names in the fromtend
Post by aimeos » 20 Nov 2017, 22:24
You can translate your new attributes using TypoScript: https://aimeos.org/docs/TYPO3/Overwrite_translations
The "domain" is "client/code" and "string" is your attribute type code.
chricken
Post by chricken » 21 Nov 2017, 08:10
Works perfect, thank you :)
