Free shipping
Free shipping
hello aimeos, is it possible to offer individual products free shipping? Without having to enter a discount code.
beste regards
derju
beste regards
derju
Re: Free shipping
What does this mean? As long as all products in the basket are marked as "free shipping" no shipping costs are added just like for digital products? For downloads, there's a service decorator available (https://aimeos.org/docs/User_Manual/Adm ... s#Download) to show or hide one of two delivery options (with and without delivery costs)
Re: Free shipping
It means if a product is in the basket, such as "free shipping" the other products in the basket are also free to deliver.
best regards
jules
best regards
jules
Re: Free shipping
How should this "free shipping product" be added to the basket?
Re: Free shipping
is it possible to set a single product to free shipping in the plugin "shipping" -"Free shipping above threshold"?
A special Product should have no shipping cost / skip the delivery process in the basket...
Re: Free shipping
This does currently only work for products in a category if the "Category,Reduction" decorators are used. You can implement a product decorator that could do the same for the configured product codes.
Re: Free shipping
Ok, thank you.
But can I create a delivery option (free shipping) and connect the Item to this option (so in the basket, "free shipping" is the only available option for this item)?
Re: Free shipping
Yes, that should be possible:
- Add the "Required" decorator to your free shipping option and add the product code to the configuration on the right
- For all other shipping options, add "Not" and "Required" as decorator with the product code configured too
Example:
Free Shipping
Provider: Manual,Required
Config: required.productcode -> abcd
All other shipping options
Provider: Manual,Not,Required
Example:
Free Shipping
