Where Do I find the original email-templates
chricken
Post by chricken » 29 Nov 2017, 14:41
I'd love to change the emails.
I understand, how to do that, but unfortunately I can not find the original template files.
Can someone give me a hint, please?
Aimeos 17.10.2-pre1 unter Typo3 8.7.8
Regards
Christian
Re: Where Do I find the original email-templates
Post by aimeos » 29 Nov 2017, 23:54
They are there: https://github.com/aimeos/ai-client-htm ... ates/email
The "payment" folder contains the e-mails sent for order confirmation.
Stefan80
Post by Stefan80 » 19 Feb 2018, 12:35
I have a question too:
I used:
plugin.tx_aimeos.settings.client.html.email.payment.text.summary.standard.template-body = email/common/text-summary-body-default-test.php
to change/add the text shown in the email , when a product is ordered ... but there is no change in the text?
Post by aimeos » 19 Feb 2018, 22:52
In TYPO3 you need to configure this in the TS-Config field of the scheduler task so it will be used. TYPO3 distinguishes configuration between frontend, backend, and scheduler
Stefan80
Post by Stefan80 » 20 Feb 2018, 08:55
Yes I did.
I want do add the bank details in the payment email sent to the customer.
Which code I use?
Post by aimeos » 20 Feb 2018, 23:59
The configuration is correct for the text version of the payment related e-mail if you enter it into the TS-Config field of the scheduler task.
Regarding your other question, please open a new thread.
