Meta Keywords
Meta Keywords
Hiho,
Is it possible to set meta keywords for an categorie or product?
I didnt found something about it in the docs.
And can i set meta keywords via typoscript?
page.meta.keywords.wrap = Keyword 1,Keyword 2,|
Typo3 7.6.x / Aimeos 17.10.0
Re: Meta Keywords
It doesn't make much sense to set the meata keywords and meta description the same for all products/categories. This would be the case if you set it via TypoScript. Instead, you can add both (and the URL segment as well) for each product/category in the text tab of the backend.
Re: Meta Keywords
Superb,
Product/Categorie under Text Tab > Meta Keywords, Url Segment.
Works very well
Works very well
