Incompatibility with Autoload of SCSS Parser
stiller
Post by stiller » 07 Mar 2018, 12:50
hi there
I'm running a site with TYPO3 8.7, t3sbootstrap, dyncss and dyncss_scss (all latest versions)
after installation of aimeos 18.1.1 the parser fails to load
Class 'Leafo\ScssPhp\Compiler' not found
Error thrown in dyncss_scss/Classes/Parser/ScssParser.php in line 17
obviously the installation of aimeos breaks the autoload routine.
anything I can do about it?
your help would be much appreciated
Re: Incompatibility with Autoload of SCSS Parser
Post by aimeos » 08 Mar 2018, 18:02
There's a composer autoloader included here:
https://github.com/aimeos/aimeos-typo3/ ... se.php#L14
If you install TYPO3 and Aimeos in composer mode, then it's not the case and you probably won't have that error.
stiller
Post by stiller » 08 Mar 2018, 23:13
thanks, but isn't there another workaround?
dyncss is quite a common extension and aimeos shouldn't interfere whith its loading calls.
I'm experiencing difficulties to install composer on my VM and don't feel very literate with this method either.
any suggestions?
Post by aimeos » 09 Mar 2018, 10:03
Can you try this pre-release: https://aimeos.org/fileadmin/download/a ... 2-pre1.zip
It removes the typo3/cms-composer-plugin which sets the TYPO3_COMPOSER_MODE constant that is interfering with the dyncss extension.
stiller
Post by stiller » 09 Mar 2018, 11:54
18.1.2-pre1 works flawlessly for me.
thank you ever so much for your quick and straightforward support
cheers
