Extend Stock (Solved)
tenkraD
Post by tenkraD » 24 Mar 2018, 14:20
Working Solution on the End Goto post6012.html#p6012
Hello Guys,
i would like to extend the stock of products with a optional field order time.
the order time is a string, and describes how long it takes for us to reorder if the product is selled out - 1 weeks/ 1 month / a few days...
1. My Problem is i cant save the values in db and dont know what im doing wrong. Also i dont get any error response, im a bit lost.
It would be great if you can help me.
I created an extension named "mhaimeos" with our extensionbuilder.
Then i extended the stock shema, this is working good.
Path: /typo3conf/ext/mhaimeos/Resources/Private/Extensions/mhaimeos/lib/custom/config/stock.php
<?php
 * Extend Database Table mshop_stock in /typo3conf/ext/aimeos/Resources/Libraries/aimeos/aimeos-core/lib/mshoplib/setup/default/schema/stock.php
 * https://aimeos.org/docs/Developers/Library/Setup_tasks/Schema_update#Modify_existing_tables
return array(
	'table' => array(
		'mshop_stock' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
			$table = $schema->getTable( 'mshop_stock' );
			$table->addColumn( 'ordertime', 'string', array( 'length' => 32 ) );
			$table->addIndex( array( 'siteid', 'ordertime' ), 'idx_mssto_sid_ordertime' );
			return $schema;
After that i created the Item
Path: /typo3conf/ext/mhaimeos/Resources/Private/Extensions/mhaimeos/lib/custom/src/MShop/Stock/Item/Mystandard.php
<?php
 * @package MShop
 * @subpackage Stock
namespace Aimeos\MShop\Stock\Item;
//namespace Mhaimeos\MShop\Stock\Item;
class Mystandard extends Standard
    private $values;
    public function __construct( array $values )
        parent::__construct( 'stock.', $values );
        $this->values = $values;
     * Returns ordertime for the product stock
     * @return string|null stock ordertime of the product
    public function getOrderTime()
        if( isset( $this->values['stock.ordertime'] ) ) {
            return (string) $this->values['stock.ordertime'];
        return '';
    public function setOrderTime( $ordertime )
        if( (string) $ordertime !== $this->getOrderTime() )
            $this->values['stock.ordertime'] = (string) $ordertime;
            $this->setModified();
        return $this;
    public function fromArray( array $list )
        $unknown = [];
        $list = parent::fromArray( $list );
        foreach( $list as $key => $value )
            switch( $key )
                case 'stock.ordertime': $this->setOrderTime( $value ); break;
                default: $unknown[$key] = $value;
        return $unknown;
    public function toArray( $private = false )
        $list = parent::toArray( $private );
        if( $private === true ) {
            $list['stock.ordertime'] = $this->getOrderTime();
        return $list;
I created the manager
Path: /typo3conf/ext/mhaimeos/Resources/Private/Extensions/mhaimeos/lib/custom/src/MShop/Stock/Manager/Mystandard.php
<?php
 * @package MShop
 * @subpackage Stock
namespace Aimeos\MShop\Stock\Manager;
//namespace Mhaimeos\MShop\Stock\Manager;
    private $searchConfig = array(
        'stock.ordertime'=> array(
            'code'=>'stock.ordertime',
            'internalcode'=>'msto."ordertime"',
            'label'=>'Product Ordertime',
            'type'=> 'string', // integer, float, etc.
            'internaltype'=> \Aimeos\MW\DB\Statement\Base::PARAM_STR, // _INT, _FLOAT, etc.
    public function saveItem( \Aimeos\MShop\Common\Item\Iface $item, $fetch = true )
        // a modified copy of the code from the parent class
        // extended by a bind() call and updated bind positions (first parameter)
    	$iface = '\\Mhaimeos\\MShop\\Stock\\Item\\Myiface';
    	if( !( $item instanceof $iface ) ) {
    		throw new \Aimeos\MShop\Stock\Exception( sprintf( 'Object is not of required type "%1$s"', $iface ) );
    	if( !$item->isModified() ) {
    		return $item;
    	$dbm = $context->getDatabaseManager();
    	$dbname = $this->getResourceName();
    	$conn = $dbm->acquire( $dbname );
    	try
    		$id = $item->getId();
    		$date = date( 'Y-m-d H:i:s' );
    		if( $id === null )
    			/** mshop/stock/manager/standard/insert/mysql
    			 * Inserts a new product stock record into the database table
    			 * @see mshop/stock/manager/standard/insert/ansi
    			/** mshop/stock/manager/standard/insert/ansi
    			 * Items with no ID yet (i.e. the ID is NULL) will be created in
    			 * the database and the newly created ID retrieved afterwards
    			 * using the "newid" SQL statement.
    			 * The SQL statement must be a string suitable for being used as
    			 * prepared statement. It must include question marks for binding
    			 * the values from the product stock item to the statement before they are
    			 * sent to the database server. The number of question marks must
    			 * be the same as the number of columns listed in the INSERT
    			 * statement. The order of the columns must correspond to the
    			 * order in the saveItems() method, so the correct values are
    			 * bound to the columns.
    			 * The SQL statement should conform to the ANSI standard to be
    			 * compatible with most relational database systems. This also
    			 * includes using double quotes for table and column names.
    			 * @param string SQL statement for inserting records
    			 * @since 2017.01
    			 * @category Developer
    			 * @see mshop/stock/manager/standard/update/ansi
    			 * @see mshop/stock/manager/standard/newid/ansi
    			 * @see mshop/stock/manager/standard/delete/ansi
    			 * @see mshop/stock/manager/standard/search/ansi
    			 * @see mshop/stock/manager/standard/count/ansi
    			 * @see mshop/stock/manager/standard/stocklevel
    			$path = 'mshop/stock/manager/standard/insert';
//    			$path = 'mshop/stock/manager/mystandard/insert';
    		else
    			/** mshop/stock/manager/standard/update/mysql
    			 * Updates an existing product stock record in the database
    			/** mshop/stock/manager/standard/update/ansi
    			 * Items which already have an ID (i.e. the ID is not NULL) will
    			 * be updated in the database.
    			 * sent to the database server. The order of the columns must
    			 * correspond to the order in the saveItems() method, so the
    			 * correct values are bound to the columns.
    			 * @param string SQL statement for updating records
    			 * @since 2017.01
    			$path = 'mshop/stock/manager/standard/update';
//    			$path = 'mshop/stock/manager/mystandard/update';
    		$stmt = $this->getCachedStatement( $conn, $path );
    		$stmt->bind( 1, $item->getProductCode() );
    		$stmt->bind( 2, $item->getTypeId(), \Aimeos\MW\DB\Statement\Base::PARAM_INT );
    		$stmt->bind( 3, $item->getStocklevel(), \Aimeos\MW\DB\Statement\Base::PARAM_INT );
    		$stmt->bind( 4, $item->getDateBack() );
 //  GET the Order Time
    		$stmt->bind( 5, $item->getOrderTime() );
    		$stmt->bind( 6, $date ); //mtime
    		$stmt->bind( 7, $context->getEditor() );
    		$stmt->bind( 8, $context->getLocale()->getSiteId(), \Aimeos\MW\DB\Statement\Base::PARAM_INT );
    		if( $id !== null ) {
    			$stmt->bind( 9, $id, \Aimeos\MW\DB\Statement\Base::PARAM_INT );
    			$item->setId( $id ); // modified false
    		} else {
    			$stmt->bind( 9, $date ); //ctime
    		$stmt->execute()->finish();
    		if( $id === null && $fetch === true )
    			/** mshop/stock/manager/standard/newid/mysql
    			 * Retrieves the ID generated by the database when inserting a new record
    			/** mshop/stock/manager/standard/newid/ansi
    			 * As soon as a new record is inserted into the database table,
    			 * the database server generates a new and unique identifier for
    			 * that record. This ID can be used for retrieving, updating and
    			 * deleting that specific record from the table again.
    			 * For MySQL:
    			 *  SELECT LAST_INSERT_ID()
    			 * For PostgreSQL:
    			 *  SELECT currval('seq_msto_id')
    			 * For SQL Server:
    			 *  SELECT SCOPE_IDENTITY()
    			 * For Oracle:
    			 *  SELECT "seq_msto_id".CURRVAL FROM DUAL
    			 * There's no way to retrive the new ID by a SQL statements that
    			 * fits for most database servers as they implement their own
    			 * specific way.
    			 * @param string SQL statement for retrieving the last inserted record ID
    			 * @since 2017.01
    			$path = 'mshop/stock/manager/standard/newid';
    			$item->setId( $this->newId( $conn, $path ) );
    		$dbm->release( $conn, $dbname );
    	catch( \Exception $e )
    		throw $e;
    	return $item;
    public function getSearchAttributes( $withsub = true )
        $list = parent::getSearchAttributes( $withsub );
        foreach( $this->searchConfig as $key => $fields ) {
            $list[$key] = new \Aimeos\MW\Criteria\Attribute\Standard( $fields );
        return $list;
    protected function createItemBase( array $values = [] /* , ... */ )
        return new \Mhaimeos\MShop\Stock\Item\Standard( $values /* , ... */ );
I created the Config
Its a copy from the existing one. I just change the name, the insert and update.
<?php
 * @copyright Aimeos (aimeos.org), 2015-2017
return array(
	'manager' => array(
		'name' => 'Mystandard',
		'type' => array(
			'standard' => array(
				'delete' => array(
					'ansi' => '
						DELETE FROM "mshop_stock_type"
						WHERE :cond AND siteid = ?
				'insert' => array(
					'ansi' => '
						INSERT INTO "mshop_stock_type" (
							"code", "domain", "label", "status",
							"mtime", "editor", "siteid", "ctime"
						) VALUES (
				'update' => array(
					'ansi' => '
						UPDATE "mshop_stock_type"
						SET "code" = ?, "domain" = ?, "label" = ?,
							"status" = ?, "mtime" = ?, "editor" = ?
						WHERE "siteid" = ? AND "id" = ?
				'search' => array(
					'ansi' => '
						SELECT mstoty."id" AS "stock.type.id", mstoty."siteid" AS "stock.type.siteid",
							mstoty."code" AS "stock.type.code", mstoty."domain" AS "stock.type.domain",
							mstoty."label" AS "stock.type.label", mstoty."status" AS "stock.type.status",
							mstoty."mtime" AS "stock.type.mtime", mstoty."editor" AS "stock.type.editor",
							mstoty."ctime" AS "stock.type.ctime"
						FROM "mshop_stock_type" mstoty
						:joins
						WHERE :cond
						GROUP BY mstoty."id", mstoty."siteid", mstoty."code", mstoty."domain",
							mstoty."label", mstoty."status", mstoty."mtime", mstoty."editor",
							mstoty."ctime" /*-columns*/ , :columns /*columns-*/
						/*-orderby*/ ORDER BY :order /*orderby-*/
						LIMIT :size OFFSET :start
				'count' => array(
					'ansi' => '
						SELECT COUNT(*) AS "count"
						FROM (
							SELECT DISTINCT mstoty."id"
							:joins
							WHERE :cond
							LIMIT 10000 OFFSET 0
						) AS list
				'newid' => array(
					'db2' => 'SELECT IDENTITY_VAL_LOCAL()',
					'mysql' => 'SELECT LAST_INSERT_ID()',
					'oracle' => 'SELECT mshop_stock_type_seq.CURRVAL FROM DUAL',
					'pgsql' => 'SELECT lastval()',
					'sqlite' => 'SELECT last_insert_rowid()',
					'sqlsrv' => 'SELECT SCOPE_IDENTITY()',
					'sqlanywhere' => 'SELECT @@IDENTITY',
			'delete' => array(
				'ansi' => '
					DELETE FROM "mshop_stock"
			'insert' => array(
				'ansi' => '
					INSERT INTO "mshop_stock" (
						"productcode", "typeid", "stocklevel", "backdate", "ordertime"
					) VALUES (
			'update' => array(
				'ansi' => '
					UPDATE "mshop_stock"
					SET "productcode" = ?, "typeid" = ?, "stocklevel" = ?,
						"backdate" = ?, "ordertime" = ?, "mtime" = ?, "editor" = ?
			'search' => array(
				'ansi' => '
					SELECT msto."id" AS "stock.id", msto."productcode" AS "stock.productcode",
						msto."siteid" AS "stock.siteid", msto."typeid" AS "stock.typeid",
						msto."stocklevel" AS "stock.stocklevel", msto."backdate" AS "stock.backdate",
					    msto."ordertime" AS "stock.ordertime",
						msto."mtime" AS "stock.mtime", msto."editor" AS "stock.editor",
						msto."ctime" AS "stock.ctime"
					FROM "mshop_stock" AS msto
					:joins
					WHERE :cond
					GROUP BY msto."id", msto."productcode", msto."siteid", msto."typeid",
						msto."stocklevel", msto."backdate", msto."ordertime", msto."mtime", msto."editor",
						msto."ctime" /*-columns*/ , :columns /*columns-*/
			'count' => array(
				'ansi' => '
					FROM (
						SELECT DISTINCT msto."id"
						:joins
						WHERE :cond
					) AS list
			'stocklevel' => array(
				'ansi' => '
					SET "stocklevel" = "stocklevel" + ?, "mtime" = ?, "editor" = ?
					WHERE :cond
			'newid' => array(
				'oracle' => 'SELECT mshop_stock_seq.CURRVAL FROM DUAL',
I edited the template
Path: /typo3conf/ext/aimeos/Resources/Private/Extensions/ai-admin-jqadm/admin/jqadm/templates/product/item-stock-default.php
<?php
$enc = $this->encoder();
$stockTypes = $this->get( 'stockTypes', [] );
<div id="stock" class="item-stock content-block tab-pane fade" role="tabpanel" aria-labelledby="stock">
	<table class="stock-list table table-default">
		<thead>
			<tr>
				<?php if( count( $stockTypes ) > 1 ) : ?>
					<th class="stock-type">
						<span class="help"><?= $enc->html( $this->translate( 'admin', 'Type' ) ); ?></span>
						<div class="form-text text-muted help-text">
							<?= $enc->html( $this->translate( 'admin', 'Warehouse or local store if your articles are available at several locations' ) ); ?>
						</div>
					</th>
				<?php endif; ?>
				<th class="stock-stocklevel">
					<span class="help"><?= $enc->html( $this->translate( 'admin', 'Stock level' ) ); ?></span>
						<?= $enc->html( $this->translate( 'admin', 'Number of articles currently in stock, leave empty for an unlimited quantity' ) ); ?>
					</div>
				</th>
				<th class="stock-databack">
					<span class="help"><?= $enc->html( $this->translate( 'admin', 'Back in stock' ) ); ?></span>
						<?= $enc->html( $this->translate( 'admin', 'Shown if the article reached a stock level of zero' ) ); ?>
					</div>
				</th>
				<th class="stock-ordertime">
					<span class="help"><?= $enc->html( $this->translate( 'admin', 'Stock Item Order Time' ) ); ?></span>
					</div>
				</th>
				<th class="actions">
					<div class="btn act-add fa" tabindex="<?= $this->get( 'tabindex' ); ?>"
						title="<?= $enc->attr( $this->translate( 'admin', 'Insert new entry (Ctrl+I)') ); ?>">
					</div>
				</th>
			</tr>
		</thead>
		<tbody>
			<?php foreach( $this->get( 'stockData/stock.id', [] ) as $idx => $id ) : ?>
				<tr class="<?= $this->site()->readonly( $this->get( 'stockData/stock.siteid/' . $idx ) ); ?>">
						<td class="stock-type mandatory">
							<select class="form-control custom-select item-typeid" required="required" tabindex="<?= $this->get( 'tabindex' ); ?>"
								name="<?= $enc->attr( $this->formparam( array( 'stock', 'stock.typeid', '' ) ) ); ?>"
								<?= $this->site()->readonly( $this->get( 'stockData/stock.siteid/' . $idx ) ); ?> >
								<option value="">
									<?= $enc->html( $this->translate( 'admin', 'Please select' ) ); ?>
								</option>
								<?php foreach( $this->get( 'stockTypes', [] ) as $typeId => $typeItem ) : ?>
									<?php if( $typeId == $this->get( 'stockData/stock.typeid/' . $idx ) ) : ?>
										<option value="<?= $enc->attr( $typeId ); ?>" selected="selected"><?= $enc->html( $typeItem->getLabel() ) ?></option>
									<?php else : ?>
										<option value="<?= $enc->attr( $typeId ); ?>"><?= $enc->html( $typeItem->getLabel() ) ?></option>
									<?php endif; ?>
								<?php endforeach; ?>
							</select>
						</td>
					<?php else : $stockType = reset( $stockTypes ); ?>
						<input class="item-typeid" type="hidden"
							value="<?= $enc->attr( $stockType ? $stockType->getId() : '' ); ?>" />
					<?php endif; ?>
					<td class="stock-stocklevel optional">
						<input class="form-control item-stocklevel" type="number" step="1" min="0" tabindex="<?= $this->get( 'tabindex' ); ?>"
							name="<?= $enc->attr( $this->formparam( array( 'stock', 'stock.stocklevel', '' ) ) ); ?>"
							value="<?= $enc->attr( $this->get( 'stockData/stock.stocklevel/' . $idx ) ); ?>"
							<?= $this->site()->readonly( $this->get( 'stockData/stock.siteid/' . $idx ) ); ?> />
					</td>
					<td class="stock-databack optional">
						<input class="form-control item-dateback" type="datetime-local" tabindex="<?= $this->get( 'tabindex' ); ?>"
							name="<?= $enc->attr( $this->formparam( array( 'stock', 'stock.dateback', '' ) ) ); ?>"
							value="<?= $enc->attr( $this->get( 'stockData/stock.dateback/' . $idx ) ); ?>"
							placeholder="<?= $enc->attr( $this->translate( 'admin', 'YYYY-MM-DD hh:mm:ss (optional)' ) ); ?>"
					</td>
					<td class="stock-ordertime optional">
						<input class="form-control item-ordertime" type="string" tabindex="<?= $this->get( 'tabindex' ); ?>"
							name="<?= $enc->attr( $this->formparam( array( 'stock', 'stock.ordertime', '' ) ) ); ?>"
							value="<?= $enc->attr( $this->get( 'stockData/stock.ordertime/' . $idx ) ); ?>"
							placeholder="<?= $enc->attr( $this->translate( 'admin', 'Order Time' ) ); ?>"
					</td>
					<td class="actions">
						<input class="item-id" type="hidden" value="<?= $enc->attr( $id ); ?>"
							name="<?= $enc->attr( $this->formparam( array( 'stock', 'stock.id', '' ) ) ); ?>" />
						<?php if( !$this->site()->readonly( $this->get( 'stockData/stock.siteid/' . $idx ) ) ) : ?>
							<div class="btn act-delete fa" tabindex="<?= $this->get( 'tabindex' ); ?>"
								title="<?= $enc->attr( $this->translate( 'admin', 'Delete this entry') ); ?>">
							</div>
						<?php endif; ?>
					</td>
				</tr>
			<tr class="prototype">
					<td class="stock-type">
						<select class="form-control custom-select item-typeid" required="required" tabindex="<?= $this->get( 'tabindex' ); ?>" disabled="disabled"
							name="<?= $enc->attr( $this->formparam( array( 'stock', 'stock.typeid', '' ) ) ); ?>">
							<option value="">
								<?= $enc->attr( $this->translate( 'admin', 'Please select' ) ); ?>
							</option>
							<?php foreach( $stockTypes as $typeId => $typeItem ) : ?>
						</select>
					</td>
				<?php endif; ?>
					<input class="form-control item-stocklevel" type="number" step="1" min="0" tabindex="<?= $this->get( 'tabindex' ); ?>" disabled="disabled"
					name="<?= $enc->attr( $this->formparam( array( 'stock', 'stock.stocklevel', '' ) ) ); ?>" />
				</td>
					<input class="form-control item-dateback" type="datetime-local" tabindex="<?= $this->get( 'tabindex' ); ?>" disabled="disabled"
						placeholder="<?= $enc->attr( $this->translate( 'admin', 'YYYY-MM-DD hh:mm:ss (optional)' ) ); ?>" />
				</td>
					<input class="form-control item-orderdate" type="string" tabindex="<?= $this->get( 'tabindex' ); ?>"
				</td>
					<input class="item-id" type="hidden" value="" disabled="disabled"
					</div>
				</td>
			</tr>
		</tbody>
	</table>
	<?= $this->get( 'stockBody' ); ?>
</div>
2. And my second Question is do i have to change the iface for order with my new function getOrderTime and setOrderTime and if yes where do i have to register the iface? I tryed it in the save function of my manager.
Path: /typo3conf/ext/mhaimeos/Resources/Private/Extensions/mhaimeos/lib/custom/src/MShop/Stock/Item/Myiface.php
<?php
 * @copyright Metaways Infosystems GmbH, 2011
 * @package MShop
 * @subpackage Stock
 * Extends Default stock item interface.
 * @package MShop
 * @subpackage Stock
interface Myiface extends Iface
	 * Returns the ordertime of the stock item.
	 * @return string Order Time
	public function getOrderTime();
	 * Sets a new Ordertime of the stock item.
	 * @param string $ordertime
	 * @return \Aimeos\MShop\Stock\Item\Iface Stock item for chaining method calls
	public function setOrderTime( $ordertime );
3. Third Question, are my namespaces correct?
4. And my last question is how do i change the templates for the extadmin, is there anything documented?
I tryed to change the ItemUI.js and ListUI.js but got this error
ext-all.js:21 Uncaught TypeError: g is not a constructor
at constructor.setConfig (ext-all.js:21)
at new constructor (ext-all.js:21)
at S.initComponent (ext-all.js:21)
at S.Ext.Component [as constructor] (ext-all.js:21)
at S [as constructor] (ext-base.js:21)
at new S (ext-base.js:21)
at S.initComponent (index.php?M=web_AimeosTxAimeosAdmin&moduleToken=60ae9e4e8faae802e56a6d72d2902be966dd9fed&tx_aimeos_web_aimeostxaimeosadmin[action]=file&tx_aimeos_web_aimeostxaimeosadmin[controller]=Extadm:3347)
at S.initComponent (index.php?M=web_AimeosTxAimeosAdmin&moduleToken=60ae9e4e8faae802e56a6d72d2902be966dd9fed&tx_aimeos_web_aimeostxaimeosadmin[action]=file&tx_aimeos_web_aimeostxaimeosadmin[controller]=Extadm:9500)
Path: /typo3conf/ext/aimeos/Resources/Private/Extensions/ai-admin-extadm/admin/extjs/src/panel/product/stock/ItemUi.js
 * Copyright (c) Metaways Infosystems GmbH, 2011
 * LGPLv3, http://opensource.org/licenses/LGPL-3.0
Ext.ns('MShop.panel.product.stock');
 * Concrete ItemUi
 * @extends Mshop.panel.AbstractListItemUi
MShop.panel.product.stock.ItemUi = Ext.extend(MShop.panel.AbstractItemUi, {
    siteidProperty : 'stock.siteid',
    initComponent : function() {
        this.title = MShop.I18n.dt('admin', 'Product stock');
        MShop.panel.AbstractItemUi.prototype.setSiteCheck(this);
        this.items = [{
            xtype : 'tabpanel',
            activeTab : 0,
            border : false,
            itemId : 'MShop.panel.product.stock.ItemUi',
            plugins : ['ux.itemregistry'],
            items : [{
                xtype : 'panel',
                title : MShop.I18n.dt('admin', 'Basic'),
                border : false,
                layout : 'hbox',
                layoutConfig : {
                    align : 'stretch'
                itemId : 'MShop.panel.product.stock.ItemUi.BasicPanel',
                defaults : {
                    bodyCssClass : this.readOnlyClass
                items : [{
                    xtype : 'form',
                    title : MShop.I18n.dt('admin', 'Details'),
                    flex : 1,
                    ref : '../../mainForm',
                    autoScroll : true,
                    items : [{
                        xtype : 'fieldset',
                        style : 'padding-right: 25px;',
                        border : false,
                        labelAlign : 'top',
                        defaults : {
                            readOnly : this.fieldsReadOnly,
                            anchor : '100%'
                        items : [{
                            xtype : 'hidden',
                            xtype : 'displayfield',
                            fieldLabel : MShop.I18n.dt('admin', 'ID'),
                            xtype : 'combo',
                            fieldLabel : MShop.I18n.dt('admin', 'Type'),
                            mode : 'local',
                            store : MShop.GlobalStoreMgr.get('Stock_Type', this.domain),
                            displayField : 'stock.type.label',
                            valueField : 'stock.type.id',
                            forceSelection : true,
                            triggerAction : 'all',
                            typeAhead : true,
                            listeners : {
                                'render' : {
                                    fn : function() {
                                        var record, index = this.store.find('stock.type.code', 'default');
                                        if((record = this.store.getAt(index))) {
                                            this.setValue(record.id);
                            xtype : 'numberfield',
                            fieldLabel : MShop.I18n.dt('admin', 'Stock level'),
                            emptyText : MShop.I18n.dt('admin', 'Quantity or empty if unlimited (optional)')
                            xtype : 'datefield',
                            fieldLabel : MShop.I18n.dt('admin', 'Back in stock'),
                            format : 'Y-m-d H:i:s',
                            emptyText : MShop.I18n.dt('admin', 'YYYY-MM-DD hh:mm:ss (optional)')
                            xtype : 'ordertime',
                            fieldLabel : MShop.I18n.dt('admin', 'Stock Order Time'),
                            emptyText : MShop.I18n.dt('admin', 'Stock Order Time')
                            fieldLabel : MShop.I18n.dt('admin', 'Created'),
                            fieldLabel : MShop.I18n.dt('admin', 'Last modified'),
                            fieldLabel : MShop.I18n.dt('admin', 'Editor'),
        MShop.panel.product.stock.ItemUi.superclass.initComponent.call(this);
    onSaveItem : function() {
        // validate data
        if(!this.mainForm.getForm().isValid() && this.fireEvent('validate', this) !== false) {
            Ext.Msg.alert(MShop.I18n.dt('admin', 'Invalid data'), MShop.I18n.dt('admin',
                'Please recheck your data'));
            return;
        this.saveMask.show();
        this.isSaveing = true;
        // force record to be saved!
        this.record.dirty = true;
        if(this.fireEvent('beforesave', this, this.record) === false) {
            this.isSaveing = false;
            this.saveMask.hide();
        this.mainForm.getForm().updateRecord(this.record);
        this.record.data['stock.productcode'] = this.listUI.itemUi.record.data['product.code'];
        if(this.action == 'add' || this.action == 'copy') {
            this.store.add(this.record);
        // store async action is triggered. {@see onStoreWrite/onStoreException}
        if(!this.store.autoSave) {
            this.onAfterSave();
    onStoreException : function() {
        this.store.remove(this.record);
        MShop.panel.product.stock.ItemUi.superclass.onStoreException.apply(this, arguments);
Ext.reg('MShop.panel.product.stock.itemui', MShop.panel.product.stock.ItemUi);
Path: /typo3conf/ext/aimeos/Resources/Private/Extensions/ai-admin-extadm/admin/extjs/src/panel/product/stock/ListUi.js
 * Copyright (c) Aimeos (aimeos.org), 2015-2017
MShop.panel.product.stock.ListUi = Ext.extend(MShop.panel.AbstractListUi, {
    recordName : 'Stock',
    idProperty : 'stock.id',
    itemUiXType : 'MShop.panel.product.stock.itemui',
    autoExpandColumn : 'product-stock-stocktype',
    filterConfig : {
        filters : [{
            dataIndex : 'stock.type.label',
            operator : '=~',
            value : ''
        this.title = MShop.I18n.dt('admin', 'Stock');
        MShop.panel.AbstractListUi.prototype.initActions.call(this);
        MShop.panel.AbstractListUi.prototype.initToolbar.call(this);
        MShop.panel.product.stock.ListUi.superclass.initComponent.call(this);
    afterRender : function() {
        this.itemUi = this.findParentBy(function(c) {
            return c.isXType(MShop.panel.AbstractItemUi, false);
        MShop.panel.product.stock.ListUi.superclass.afterRender.apply(this, arguments);
    onBeforeLoad : function(store, options) {
        this.setSiteParam(store);
        if(this.domain) {
            this.setDomainFilter(store, options);
        options.params = options.params || {};
        options.params.condition = {
                    'stock.productcode' : this.itemUi.record ? this.itemUi.record.data['product.code'] : ''
    getColumns : function() {
        this.typeStore = MShop.GlobalStoreMgr.get('Stock_Type');
        return [
                xtype : 'gridcolumn',
                dataIndex : 'stock.id',
                header : MShop.I18n.dt('admin', 'ID'),
                sortable : true,
                width : 50,
                hidden : true
                dataIndex : 'stock.productcode',
                header : MShop.I18n.dt('admin', 'Product code'),
                width : 50,
                hidden : true
                dataIndex : 'stock.typeid',
                header : MShop.I18n.dt('admin', 'Type'),
                align : 'center',
                renderer : this.typeColumnRenderer.createDelegate(this, [
                    this.typeStore,
                    "stock.type.label"], true)
                dataIndex : 'stock.stocklevel',
                header : MShop.I18n.dt('admin', 'Stock level'),
                sortable : true,
                align : 'center',
                width : 80
                xtype : 'datecolumn',
                dataIndex : 'stock.dateback',
                header : MShop.I18n.dt('admin', 'Date back'),
                sortable : true,
                width : 130
                dataIndex : 'stock.ordertime',
                header : MShop.I18n.dt('admin', 'Order Time'),
                sortable : true,
                width : 130
                dataIndex : 'stock.ctime',
                header : MShop.I18n.dt('admin', 'Created'),
                sortable : true,
                width : 130,
                editable : false,
                hidden : true
                dataIndex : 'stock.mtime',
                header : MShop.I18n.dt('admin', 'Last modified'),
                sortable : true,
                width : 130,
                editable : false,
                hidden : true
                dataIndex : 'stock.editor',
                header : MShop.I18n.dt('admin', 'Editor'),
                sortable : true,
                width : 130,
                editable : false,
                hidden : true
Ext.reg('MShop.panel.product.stock.listui', MShop.panel.product.stock.ListUi);
Ext.ux.ItemRegistry.registerItem('MShop.panel.product.ItemUi', 'MShop.panel.product.stock.listui', MShop.panel.product.stock.ListUi, 2);
Many Thanks and sorry for the long post ;)
Typo3 7.6.x / Aimeos 17.10.0
Re: Extend Stock to Save a new Value
Post by aimeos » 26 Mar 2018, 09:01
The namespace/class name of your item in createItemBase() (manager class) is wrong. It must be \Aimeos\MShop\Stock\Item\MyStandard. The rest seems to be OK.
If you don't have a clue, add some debug output to see which code is executed.
Regarding the ExtJS interface: Forget about it!
In 2017.x it's deprecated and in the 2018.x version it's already removed.
mohal_04
Post by mohal_04 » 30 Mar 2018, 12:51
tenkraD wrote:Hello Guys,
<?php
return array(
	'table' => array(
			return $schema;
<?php
 * @package MShop
 * @subpackage Stock
    private $values;
        return '';
        return $this;
        $unknown = [];
            switch( $key )
        return $unknown;
        return $list;
<?php
 * @package MShop
 * @subpackage Stock
    		return $item;
    	try
    		if( $id === null )
    			 * @since 2017.01
    		else
    			 * @since 2017.01
    		} else {
    			 * For MySQL:
    			 * For PostgreSQL:
    			 * For SQL Server:
    			 * For Oracle:
    			 * specific way.
    			 * @since 2017.01
    		throw $e;
    	return $item;
        return $list;
<?php
return array(
	'manager' => array(
		'type' => array(
				'delete' => array(
					'ansi' => '
				'insert' => array(
					'ansi' => '
						) VALUES (
				'update' => array(
					'ansi' => '
				'search' => array(
					'ansi' => '
						:joins
						WHERE :cond
				'count' => array(
					'ansi' => '
						FROM (
							:joins
							WHERE :cond
						) AS list
				'newid' => array(
			'delete' => array(
				'ansi' => '
			'insert' => array(
				'ansi' => '
					) VALUES (
			'update' => array(
				'ansi' => '
			'search' => array(
				'ansi' => '
					:joins
					WHERE :cond
			'count' => array(
				'ansi' => '
					FROM (
						:joins
						WHERE :cond
					) AS list
				'ansi' => '
					WHERE :cond
			'newid' => array(
<?php
		<thead>
			<tr>
						</div>
					</th>
				<?php endif; ?>
					</div>
				</th>
					</div>
				</th>
					</div>
				</th>
					</div>
				</th>
			</tr>
		</thead>
		<tbody>
								<option value="">
								</option>
									<?php else : ?>
									<?php endif; ?>
							</select>
						</td>
					<?php endif; ?>
					</td>
					</td>
					</td>
							</div>
						<?php endif; ?>
					</td>
				</tr>
							<option value="">
							</option>
						</select>
					</td>
				<?php endif; ?>
				</td>
				</td>
				</td>
					</div>
				</td>
			</tr>
		</tbody>
	</table>
</div>
<?php
 * @package MShop
 * @subpackage Stock
 * @package MShop
 * @subpackage Stock
 * Concrete ItemUi
        this.items = [{
            xtype : 'tabpanel',
            activeTab : 0,
            border : false,
            items : [{
                xtype : 'panel',
                border : false,
                layout : 'hbox',
                layoutConfig : {
                    align : 'stretch'
                defaults : {
                items : [{
                    xtype : 'form',
                    flex : 1,
                    autoScroll : true,
                    items : [{
                        xtype : 'fieldset',
                        border : false,
                        labelAlign : 'top',
                        defaults : {
                            anchor : '100%'
                        items : [{
                            xtype : 'hidden',
                            xtype : 'combo',
                            mode : 'local',
                            typeAhead : true,
                            listeners : {
                                'render' : {
                                    fn : function() {
        // validate data
            return;
            this.onAfterSave();
    filterConfig : {
        filters : [{
            operator : '=~',
            value : ''
        if(this.domain) {
        return [
                sortable : true,
                width : 50,
                hidden : true
                width : 50,
                hidden : true
                align : 'center',
                    this.typeStore,
                sortable : true,
                align : 'center',
                width : 80
                sortable : true,
                width : 130
                sortable : true,
                width : 130
                sortable : true,
                width : 130,
                editable : false,
                hidden : true
                sortable : true,
                width : 130,
                editable : false,
                hidden : true
                sortable : true,
                width : 130,
                editable : false,
                hidden : true
Have you fixed your problem? I am facing an issue and have been struggling to fix it. Can you help me? I want to add a new field in Product form on Admin side.
Thanks!
tenkraD
Post by tenkraD » 02 Apr 2018, 22:00
was in hollidays and not here sorry. ya, its working now. where do u have problems
mohal_04
Post by mohal_04 » 03 Apr 2018, 09:31
tenkraD wrote:was in hollidays and not here sorry. ya, its working now. where do u have problems
I have rewritten my code 3 times and now the situation is this... I am able to display value in my extra field but it is not saving in the DB and there are no errors :(. Please, look at my code and guide me!
./ext/myextension/lib/custom/setup/default/schema/product.php
return array(
	'table' => array(
		'mshop_product' => function ( \Doctrine\DBAL\Schema\Schema $schema ) {
			// $table = $schema->createTable( 'mshop_price' );
			$table = $schema->getTable( 'mshop_product' );
			$table->addColumn( 'oldcode', 'string', array( 'length' => 32 ) );
			$table->addIndex( array( 'siteid', 'oldcode' ), 'idx_msproty_sid_oldcode' );
			return $schema;
./ext/myextension/lib/custom/src/MShop/Product/Item/Myproject.php
namespace Aimeos\MShop\Product\Item;
class Myproject extends Standard
    private $myvalues;
    public function __construct(array $values)
        parent::__construct($values);
        $this->myvalues = $values;
    public function getOldCode()
        if( isset( $this->myvalues['product.oldcode'] ) ) {
            return (string) $this->myvalues['product.oldcode'];
        return '';
    public function setOldCode( $oldcode )
        if ((string) $oldcode !== $this->getOldCode()) {
            // exit("<br />616");
            $this->myvalues['product.oldcode'] = (string) $oldcode;
        return $this;
    public function fromArray(array $list)
        $unknown = [];
        $list = parent::fromArray($list);
        foreach ($list as $key => $value) {
            switch ($key) {
                case 'product.oldcode':
                    $this->setOldCode($value);
                    break;
                default:
        // exit("<br />617");
        return $unknown;
            $list['product.oldcode'] = $this->getOldCode();
        return $list;
./ext/myextension/lib/custom/src/MShop/Product/Manager/Myproject.php
namespace Aimeos\MShop\Product\Manager;
        'product.oldcode'=> array(
            'code'=>'product.oldcode',
            'internalcode'=>'mpro."oldcode"',
            'label'=>'Product oldcode',
    public function saveItem(\Aimeos\MShop\Common\Item\Iface $item, $fetch = true)
        $iface = '\\Aimeos\\MShop\\Product\\Item\\Iface';
        if (! ($item instanceof $iface)) {
            throw new \Aimeos\MShop\Product\Exception(sprintf('Object is not of required type "%1$s"', $iface));
        if (!$item->isModified()) {
            return $item;
        try {
            $date = date('Y-m-d H:i:s');
            if ($id === null) {
                $path = 'mshop/product/manager/standard/insert';
            } else {
                $path = 'mshop/product/manager/standard/update';
            $stmt = $this->getCachedStatement($conn, $path);
            $stmt->bind(1, $item->getTypeId(), \Aimeos\MW\DB\Statement\Base::PARAM_INT);
            $stmt->bind(2, $context->getLocale()->getSiteId(), \Aimeos\MW\DB\Statement\Base::PARAM_INT);
            $stmt->bind(3, $item->getCode());
            $stmt->bind(4, $item->getLabel());
            $stmt->bind(5, json_encode($item->getConfig()));
            $stmt->bind(6, $item->getDateStart());
            $stmt->bind(7, $item->getDateEnd());
            $stmt->bind(8, $item->getStatus(), \Aimeos\MW\DB\Statement\Base::PARAM_INT);
            $stmt->bind(9, $date); // mtime
            $stmt->bind(10, $context->getEditor());
            $stmt->bind(11, $item->getTarget());
            $stmt->bind(12, $item->getOldCode());
                $stmt->bind( 13, $id, \Aimeos\MW\DB\Statement\Base::PARAM_INT );
                $item->setId( $id ); //so item is no longer modified
            } else {
                $stmt->bind( 13, $date ); // ctime
                $path = 'mshop/product/manager/standard/newid';
        } catch (\Exception $e) {
            throw $e;
        return $item;
        return $list;
    protected function createItemBase(array $values = [], array $listitems = [],
        array $refItems = [], array $propertyItems = [])
        return new \Aimeos\MShop\Product\Item\Myproject($values, $listitems, $refItems, $propertyItems);
and
./ext/myextension/lib/custom/config/mshop.php
return [
    'product' => [
        'manager' => [
            'name' => 'Myproject',
            'standard' => [
				'insert' => array(
					'ansi' => '
						INSERT INTO "mshop_product" (
							"typeid", "siteid", "code", "label", "config", "start", "end",
							"status", "mtime", "editor", "target", "ctime", "oldcode"
						) VALUES (
				'update' => array(
					'ansi' => '
						UPDATE "mshop_product"
						SET "typeid" = ?, "code" = ?, "label" = ?, "status" = ?,
							"start" = ?, "end" = ?, "config" = ?, "mtime" = ?, "editor" = ?, "target" = ?, "oldcode" = ?
				'search' => array(
					'ansi' => '
						SELECT mpro."id" AS "product.id", mpro."siteid" AS "product.siteid",
							mpro."typeid" AS "product.typeid", mpro."code" AS "product.code",
							mpro."label" AS "product.label", mpro."config" AS "product.config",
							mpro."start" AS "product.datestart", mpro."end" AS "product.dateend",
							mpro."status" AS "product.status", mpro."ctime" AS "product.ctime",
							mpro."mtime" AS "product.mtime", mpro."editor" AS "product.editor",
							mpro."target" AS "product.target",
							mpro."oldcode" AS "product.oldcode"
						FROM "mshop_product" AS mpro
						:joins
						WHERE :cond
						GROUP BY mpro."id", mpro."siteid", mpro."typeid", mpro."code",
							mpro."label", mpro."config", mpro."start", mpro."end",
							mpro."status", mpro."ctime", mpro."mtime", mpro."editor",
							mpro."target", mpro."oldcode"
				'count' => array(
					'ansi' => '
						FROM (
							SELECT DISTINCT mpro."id"
							:joins
							WHERE :cond
						) AS list
				'newid' => array(
					'oracle' => 'SELECT mshop_product_seq.CURRVAL FROM DUAL',
Everything seems fine but still I am unable to save value for my custom field, i.e. oldcode.
Thanks!
tenkraD
Post by tenkraD » 03 Apr 2018, 11:42
Looks good but i see 2 differences,
1. I created my extension with the extensionbuilder https://aimeos.org/developer/extensions/ and got another directory structur as you. In the extensionbuilder i have select "Typo3 2018.x Extension" because im using the 2018 Aimeos Extension in Typo3. Perhaps this is making u some problems, dont really know.
2. I extended the standard Iface that my new functions from Item.php in Manager.php can be used.
Create src/MShop/Product/Item/Myiface.php
<?php
	public function getOldCode();
	public function setOldCode( $oldcode );
2b. In Manager in the saveItem function use ure new Iface "Myiface"
        $iface = '\\myextension\\lib\\custom\\src\\MShop\\Product\\Item\\Myiface';
mohal_04
Post by mohal_04 » 03 Apr 2018, 11:54
Thanks to Almighty Allah, I have solved my issue. Complete solution can be found on following link: post5939.html#p5939
Thanks!
tenkraD
Post by tenkraD » 03 Apr 2018, 12:01
Nice
mohal_04
Post by mohal_04 » 04 Apr 2018, 06:25
tenkraD wrote:Nice
Yes, it was nice for moments until I see that it has somehow stopped saving some other data for product. For example, it is not saving Product images. I wonder what is the connection? I guess I have to extend those classes also, which is too dumb.
Can you guide me with this?
Thanks!
tenkraD
Post by tenkraD » 04 Apr 2018, 15:57
Im a bit in hurry and have not much time to look at ure code. But the master jedi alias "Administrator" surely knows some help.
I saw just one thing: In ure manager in createItemBase change $listitems to $listItems.
Cya and good luck
