Unic order ID
Unic order ID
Hi! I have two shops on aimeos and i have situation, when i got same orders ID on my email. So how can change order ID like this: FR1-FRNNN. I just want to add Letters to begining of Order ID.
Thank you!
Thank you!
Re: Unic order ID
The order IDs are auto_incement values from MySQL so you can only add prefixes when e.g. the e-mail is sent to you.
Re: Unic order ID
OK, i see. To add prefix to email i need to change email template or theris any config for this?
Re: Unic order ID
Yes, copy the e-mail template to your own extension and modify the line where it outputs the order ID
