JSONAPI Mini-Basket update does not work
stiller
Post by stiller » 05 Jun 2018, 09:46
hi there.
I'm expiriencing problems to update the mini-basket without page reload.
the JSONAPI url contains escaping backslashes and returns a 404
"basket":"http:\/\/typo3.demo.aimeos.org\/demo\/jsonapi\/r\/basket\/"
the demo systems does not show this behaviour
what is causing this? php settings?
how can I avoid it?
any advice appreciated
aimeos 18.1.1
typo3 8.7.10
php 7.0.30
cheers
Re: JSONAPI Mini-Basket update does not work
Post by aimeos » 06 Jun 2018, 07:19
The backslashes are normal because they are added by json_encode() to conform to the JSON specification. Your problem must be a different one.
stiller
Post by stiller » 06 Jun 2018, 11:16
no need to investigate further.
I've figured out today that the jsaonapi is not working with typo3 debug modus on.
switching if off produced correct urls without backslashes.
thank you
