Language DE and FR
xbluex
Language DE and FR
Post by xbluex » 07 Jun 2018, 10:03
i want to use the AIMEOS Shop for the languages DE and FR.
I found the Documentation
"https://aimeos.org/docs/Configuration/C ... ale_select"
But it don't works, i dosen't get a language menu in header or body.
Who can help me?
Re: Language DE and FR
Post by aimeos » 07 Jun 2018, 16:38
"Doesn't work" is no helpful description of your problem. First of all: Which environment do you use?
xbluex
Post by xbluex » 07 Jun 2018, 18:56
I work in a TYPO3 8.7.15 version and users the demo installation of the aimeos shop system which i choosen in the TYPO3 backend after the installation ...
I type the script parts from the documentation (link at the first post) in the setup part of the +ext template ... in the docu it views a select-field for select the language... i don‘t get a select field...
I hope you can understand mi problem, mi english is not very good ...
Post by aimeos » 10 Jun 2018, 11:03
You don't have to configure much. You only need to add the Locale Select plugin to your pages.
As language selection is usually done by using TYPO3 methods, you can remove that part from the Locale Select component so only currency selection is left over: https://aimeos.org/docs/TYPO3/Configure ... d_currency
If you have problems adding a TYPO3 language selector or placing the Locale Select output somewhere in your navigation bar, please consult the TYPO3 documentation or ask in the TYPO3 forums for help.
