DirectDebit Configuration is missing
koellen
Post by koellen » 11 Jul 2018, 14:37
Hello Aimeos,
I'am about to setup a small installation.
We have added postpay and DirectDebit as payment provider.
Everything is fine except when the user doesn't fill in the details for direct debit.
We get the following messages:
Configuration for "directdebit.accountno" is missing
Configuration for "directdebit.bankcode" is missing
Configuration for "directdebit.bankname" is missing
I asume this should say: "Please enter your account number" etc.
But I can't figure out where to configure these messages.
Aimeos Version: 17.10.1
Typo3: 8.7.16
Re: DirectDebit Configuration is missing
Post by aimeos » 14 Jul 2018, 12:55
That's a bit more complicated than it should be. The error messages are generated here:
https://github.com/aimeos/aimeos-core/b ... e.php#L318
And they are displayed in the template of the checkout process in the HTML client:
https://github.com/aimeos/ai-client-htm ... lt.php#L81
What you can do now is to copy the body-defaultphp template to your own Aimeos extension so you can modify it and change
<li class="error-item"><?= $enc->html( $errmsg ); ?></li>
to
<li class="error-item"><?= $enc->html( $this->translated( 'error', $errmsg ) ); ?></li>
Then, you can translate the complete error message using TypoScript with
plugin.tx_aimeos.settings.i18n.en.0 {
  domain = error
  string = Configuration for "directdebit.accountno" is missing
  trans = Please enter your account number
More about overwriting translations in TYPO3 is written here: https://aimeos.org/docs/TYPO3/Overwrite_translations
koellen
Post by koellen » 17 Jul 2018, 08:23
Thanks for the hints.
I copied the file into my extension but had to alter the line to:
<li class="error-item"><?= $enc->html( $this->translate( 'client', $errmsg ) ); ?></li>
for the domain "error" is not known in 2017.10.
Then you can translate it with TypoScript:
  domain = client
