How to add with a link a product to Cart with Quantity
crazyforester
Post by crazyforester » 05 Sep 2018, 11:05
I don’t know if it is possible, but I would like to create links to Detail view of an article
i.e. demo site link
http://typo3.demo.aimeos.org/demo/detai ... article/0/
but “Add to basket” quantity to be changed to 5
It is possible in other system with url, i.e. ../?add-to-cart=2&quantity=5
Articles are small numbers, so links could be created manually in my page
Thank you in advance even for a small hint how it could be done.
Re: How to add with a link a product to Cart with Quantit
Post by aimeos » 05 Sep 2018, 20:17
You may use something like this for TYPO3:
...&ai[b_action]=add&ai[b_prod][0][prodid]=15&ai[b_prod][0][quantity]=5
More details about the used parameters is available in the docs:
https://aimeos.org/docs/Developers/Html ... mes#Basket
tomvolz
Re: How to add with a link a product to Cart with Quantity
Post by tomvolz » 22 Feb 2025, 20:54
"...&ai[b_action]=add&ai[b_prod][0][prodid]=15&ai[b_prod][0][quantity]=5"
Worked in TYPO3 9.5
How to add with a link a product to Cart with Quantity in TYPO3 12?
Post by aimeos » 24 Feb 2025, 13:03
The parameters haven't changed so it should work in TYPO v12+ too as long as there's no change at TYPO3 routing side (GET vs POST request).
