Access to products only by link
Moritz
Post by Moritz » 12 Dec 2018, 12:39
is it possible to have products that aren't shown anywhere in lists or search results but are accessible by it's link?
Best regards,
Moritz
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Re: Access to products only by link
Post by aimeos » 13 Dec 2018, 10:52
Sure, only add them to no category. The product detail pages are accessible using the normal detail URL (d_prodid for the ID parameter is the important part)
Moritz
Post by Moritz » 13 Dec 2018, 11:42
Thank you for answering!
Ahh, okay. That works for me.
But only when I create a new product without category.
When I edit an existing product and remove those categories it is still shown in lists and search result...
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 13 Dec 2018, 23:05
Yeah, exactly one category is still in the index in this case. It's fixed with that patch:
https://github.com/aimeos/aimeos-core/c ... 63f7ac7d60
Moritz
Post by Moritz » 14 Dec 2018, 06:56
Thank you! That solves my problem.
PHP 8.2.24
Typo3 v12.4.23 LTS
