Aimeos mobile app
boettner
Aimeos mobile app
Post by boettner » 30 Jan 2019, 09:49
Hi all,
is anyone aware of an existing aimeos mobile app frontend for iOS and Android?
Regards
Robert.
Re: Aimeos mobile app
Post by aimeos » 31 Jan 2019, 13:09
We don't think so. There's research going on to integrate vuestorefront as PWA into Aimeos:
https://www.vuestorefront.io/
Inwizards45
Post by Inwizards45 » 19 Jun 2019, 12:19
How do I integrate aimeos with angular 2(frontend for desktop) and ionic framework(frontend for mobile apps)?
Post by aimeos » 20 Jun 2019, 19:53
AndreyFedotov
Post by AndreyFedotov » 11 Mar 2021, 06:31
How can I manage basket for mobile apps and frontend frameworks like vuejs if basket can be fetched only using cookies. Question is how can I update storage to database and store added products to basket in database and fetch them using user's token. I can do everything except basket storage driver. Please help me
Post by aimeos » 12 Mar 2021, 08:48
Don't know if this it's possible to avoid the session cookie. You will need another session token and you should check if there's a Laravel package that offers such functionality.
