CSV product import: Downloads
Moritz
Post by Moritz » 27 Feb 2019, 13:49
Is there a possibility to attach download files to a product when importing a CSV?
For images I can use 'media.url' and the relative path to it.
I didn't find anything similar for download files...
Grettings
Moritz
PHP 8.2.24
Typo3 v12.4.23 LTS
Aimeos web shop 24.10.2
Re: CSV product import: Downloads
Post by aimeos » 01 Mar 2019, 11:18
It's possible but requires a bit more understanding how Aimeos saves downloads internally. They are "hidden" attributes of type "download" with the relative URL inside the secure file system (usually ./uploads/tx_aimeos/.secure/).
Moritz
Post by Moritz » 08 Mar 2019, 11:50
So I should store the download file into my secure upload folder?
Is there any rule that I have to consider? Like the naming or folder structure?
Can you tell me which of the following values should be filled for the import and where do I place the relativ download path?
    array(
    	'attribute' => array(
    		0 => 'attribute.typeid',
    		1 => 'attribute.type',
    		2 => 'attribute.code',
    		3 => 'attribute.label',
    		4 => 'attribute.position',
    		5 => 'attribute.status',
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 08 Mar 2019, 17:28
There's not required nameing for the secure folder. We store md5 hashes like "a0...f9.jpg" so we are sure there's no potential security issue.
You should use:
- attribute.type = "download"
- attribute.code = "a0...f9.jpg"
- attribute.label = "myfile.jpg"
- attribute.position = 0
- attribute.status = 1
Moritz
Post by Moritz » 20 Mar 2019, 14:44
That doesn't work because the download is stored as normal attribute instead of hidden attribute.
How can I import it as hidden attribute?
PHP 8.2.24
Typo3 v12.4.23 LTS
Post by aimeos » 21 Mar 2019, 12:59
Add "product.list.type" => hidden to your mapping and your data:
https://aimeos.org/docs/Developers/Cont ... #Attribute
Moritz
Post by Moritz » 21 Mar 2019, 13:41
Perfect, that works.
Thank you!
PHP 8.2.24
Typo3 v12.4.23 LTS
