installation problem
crazyforester
Post by crazyforester » 09 Apr 2019, 05:30
I use Typo3 9.5.5 and Aimeos is 19.1.0
At the backend when I want to enter Aimeos panel I see the following error
No item found for conditions: Array ( [locale.site.code] => default )
Also, when I start the update script there is an error
Checking table "mshop_attribute":
SQLSTATE[42000]: Syntax error or access violation: 1071 Specified key was too long; max key length is 767 bytes
I appreciate your help
Re: installation problem
Post by aimeos » 09 Apr 2019, 19:12
You use a MySQL 5.6 database which doesn't support long indexes. Please read https://github.com/aimeos/aimeos-typo3#database-setup
