Account creation - Password field not set
cyrotek
Post by cyrotek » 27 Jun 2019, 16:47
Hello everybody,
starting to get the hang of aimeos.
Pretty much everything works as far as I can tell, just every user that is created has an empty password field and I can't figure out why.
Typo3 9.5.7
Aimeos 19.4.3
aimeos_pay 19.4.1
Hoping for a fast and simple Solution.
Regards
Note: The email is sent with a password and username though, just never gets into the DB. Usergroup and PID is correct.
Re: Account creation - Password field not set
Post by aimeos » 28 Jun 2019, 13:17
Caused by a minor bug in the ai-client-html extension. A new minor version has been tagged and here's the link to an updated TYPO3 package: https://aimeos.org/fileadmin/download/a ... 4-pre1.zip
cyrotek
Post by cyrotek » 02 Jul 2019, 09:39
Is it possible to tell me which file/s were affected? I've made quite a few modifications and use my own "extension" to implemt the changes in html templates.
Post by aimeos » 02 Jul 2019, 09:56
It's that change: https://github.com/aimeos/ai-client-htm ... 8f650eb81c
Please don't modify core files as you can overwrite anything in your own extension!
cyrotek
Post by cyrotek » 02 Jul 2019, 11:04
Alright, I did try to implement my own Version of that File, but how / where do I tell my installation to actually use that instead of the original? For templates it worked out of the box, without any additions needed.
Post by aimeos » 02 Jul 2019, 11:20
You have to name your file/class differently and configure the new name:
https://aimeos.org/docs/Configuration/C ... count/name
cyrotek
Post by cyrotek » 02 Jul 2019, 12:01
The "fix" was installed, password field still empty though.
Post by aimeos » 03 Jul 2019, 08:51
Are you sure your new class is used?
cyrotek
Post by cyrotek » 03 Jul 2019, 09:06
For testing purposes i changed it in the core file, to have it up to date and yea, that is used as the "createLDAPUser" Function is still being fired.
Post by aimeos » 03 Jul 2019, 17:31
