Stock import CSV not available
cnoelker
Post by cnoelker » 09 Aug 2019, 10:18
I update to the Aimeos 19.7.1 and TYPO3 9.5.8 LTS. Now, the stock import CSV is gone. It's not available in the scheduler and when I start the CLI, then it throws an error message.
typo3cms aimeos:jobs stock/import/csv default
Why has this been removed from ai-controller-jobs? What is the replacement?
Claudia
Re: Stock import CSV not available
Post by aimeos » 09 Aug 2019, 11:27
The product CSV import can do the same. You can configure it with product code and stock level to work with existing files.
cnoelker
Post by cnoelker » 09 Aug 2019, 11:36
Where is this documented? I think, it's not at all developer friendly, if you silently remove a functionality...
Post by aimeos » 09 Aug 2019, 11:44
Sorry, we've introduced that in 2019.04 but found out that it's duplicate code and removed that in 2019.07 immediately again. We should have been communicating better ...
cnoelker
Post by cnoelker » 09 Aug 2019, 13:44
For me, it was not duplicated. I was using product/import/csv to update the status of a select product and stock/import/csv to import the stock of default products.
The solution is to combine both into one import.
Post by aimeos » 09 Aug 2019, 13:56
You can use two scheduler task with different configurations in the TSConfig field
cnoelker
Post by cnoelker » 10 Aug 2019, 10:02
How can I do this? On CLI, I start the import with
typo3cms aimeos:jobs product/import/csv default
I don't see a way to provide any parameters.
Post by aimeos » 11 Aug 2019, 12:13
Right, if you use the job controllers from the command line directly that won't work. This is also a problem in Laravel, Symfony, etc. and therefore, we've decided to add the stock importer again (2019.07.4).
cnoelker
Post by cnoelker » 12 Aug 2019, 08:21
That's a good decision.
For me a bit too late. I did already change my import so that status update and stock update are done at the same time.
cnoelker
Post by cnoelker » 04 Nov 2019, 15:29
I moved back to the CSV import. So my CSV is simple, e.g.
4026708154934,10
4026708154935,0,2019-12-20
However, the '2019-12-20' is imported as the stock type, not the date when the item is available, again.
Providing the date as the fourth value in the CSV did not work, either.
So, I have to (again) switch to the XML import for the stock?
Claudia
