Adding columns in backend list views is not possible
boettner
Post by boettner » 02 Oct 2019, 07:20
Hi all,
I´m using aimeos 18.10.9 in TYPO3 9.5.9 and can´t add/remove columns in backend list views (Orders, Products, Customers, ...). No JS error in console no requests being sent.
Is this a known error. Should I file a Github issue?
Best
Robert.
Re: Adding columns in backend list views is not possible
Post by aimeos » 02 Oct 2019, 07:25
Are you hitting the loupe button after selecting the columns you want to display so your chosen columns will be displayed?
boettner
Post by boettner » 02 Oct 2019, 07:28
No I didn´t :lol:
Good to know and problem solved. Thanks, that was lightning fast!
