"Add teacher" option for a "course" product
rowild
Post by rowild » 03 Oct 2019, 13:02
The shop provides courses for acting students. One type of course can be tought by different teachers at different dates and times, so we decided to create a separate product for each of these courses.
But in the backend we would like to somehow be able to select the teacher from a prepared list, instead of always typing it out. It would also be great to have this teacher connected with some text that could be shown as a popup.
To get a better idea of what I mean: this is the current "shop" using formhandler which shall be exchanged with aimeos:
https://www.schauspielschule.at/29/
What would be the best way to do that? (I was thinking about mis-using "supplier for that, but this field does not show up in the product creation interface.)
(This "selection" should only be available in the backend; we do not want the customer to choose from select boxes in the front end. Unless you recommend us to do so, because it is the better way?)
Thank you!
Re: "Add teacher" option for a "course" product
Post by aimeos » 03 Oct 2019, 16:41
Using suppliers for that isn't a "mis-use" but a perfect match instead ;-)
There's currently no sub-panel for adding suppliers to products but that's rather easy to implement if you use the "Categories" panel as reference for copy&paste. A pull request on Github for that is very welcome!
rowild
Post by rowild » 05 Oct 2019, 06:11
Hmm... I really would like to try that. But I encounter another problem:
I follow the git workflow you provide here: https://aimeos.org/docs/Developers/Git_workflow
I fork the aimeos-typo3 repo
Then I clone my aimeos-typo3 repo to a local place on my computer.
But how do I install the extension into TYPO3? And how do I manage all the git related workflow in the installed extensions? How can I require a package from a local storage?
Special case (not concerning me at the moment, but would like to know): How would all that work in a TYPO3 environment that itself might be a clone with its own git repo at the root?
Thank you!
rowild
Post by rowild » 06 Oct 2019, 06:43
Having tried out quite a lot (see Slack https://typo3.slack.com/archives/C025BQ ... 6766254500), I came to the point, that you at aimeos should provide a clear instruction on how to setup a proper composer-based development setup that is good for providing PRs. Your current instructions in the docu are by far not sufficient, and I for myself could not come up with a useable solution. But you are the pro's, so i count on you! Even though I have to say that my guts tell me this is actually not possible (with composer and git and no overrides on all those pulls once a manual change was done...).
This is very discouraging, to be honest. I wish you could provide better instructions, if you expect PRs...
Post by aimeos » 07 Oct 2019, 08:50
What are you missing to create a successful PR for the Aimeos core in https://aimeos.org/docs/Developers/Git_workflow?
