Language Support for Scheduler Task
stiller
Post by stiller » 25 Oct 2019, 11:49
hi there.
how is it possible to add language support to the scheduler task in order to attach different pdf-files to the payment mails.
conditions do not work here.
eg.
client.html.email {
  payment.attachments {
  0 = AGB.pdf
[globalVar = GP:L = 1]
client.html.email {
  0 = AGB_EN.pdf
[global]
TYPO3 8.7.27
Aimeos 18.10.9
cheers
Re: Language Support for Scheduler Task
Post by aimeos » 26 Oct 2019, 08:44
No, that doesn't work because you don't have GET/POST available in scheduler tasks. Instead, you have to extend the HTML client for your needs: https://github.com/aimeos/ai-client-htm ... #L114-L116
stiller
Post by stiller » 30 Oct 2019, 17:42
thank you!
how would you query the language id at this point?
Post by aimeos » 31 Oct 2019, 08:57
Use
$view->extAddressItem->getLanguageId()
if available or
$view->extOrderBaseItem->getLocale()->getLanguageId()
for the language used during the checkout process. You can see the assigned objects to the view here:
https://github.com/aimeos/ai-client-htm ... #L255-L258
stiller
Post by stiller » 07 Nov 2019, 23:56
the latter has worked
thank you!
