categories do not show up in product
einmaku
Post by einmaku » 08 Nov 2019, 11:16
When I want to add several categories to a product - the dropdown window doesn't show all categories/subcategories.
If I type the categorie in, the subcategories do not show up neither.
Thanks for help and solve the problem.
Re: categories do not show up in product
Post by aimeos » 09 Nov 2019, 11:25
This is a combobox with a limit of 25 entries. If you type in the first characters of the category or sub-category, the list is reloaded via AJAX and reduced to the matching categories
einmaku
Post by einmaku » 09 Nov 2019, 11:49
I tried what you propose - I realize I did not wait long enough...........
It takes up to 7 seconds
thnaks anyway
Post by aimeos » 09 Nov 2019, 11:54
That's too long, normally it takes only 200-500ms. Maybe a misconfigured server?
Urs
Post by Urs » 30 Sep 2024, 15:34
In my case the categories do no shop up because "the list is empty". I have created 8 main categories.
On the other hand, in "Categories", when I want to insert a new product entry and click on "Product ID, SKU or Label", it's the list of the categories that's poping up! ?
I'm using
Typo3 12.4.19
aimeos 23.10.7
PHP 8.3
MySQL 8.0.39
Post by aimeos » 02 Oct 2024, 07:53
Can you create a video showing the problems?
Urs
Post by Urs » 10 Oct 2024, 16:14
I have updated the tables with Typo3 Upgrade Wizard and the problem was solved.
