Wrong Behavior Required & BasketValues Decorator
cyrotek
Post by cyrotek » 29 Nov 2019, 10:06
Hey, i just stumbled upon a bug so it seems.
When I add the required or basketvalue decorator occaciosnaly it does not work. More often, when i apply a coupon, hit the checkout, it works (mostly), though, when i go back, delete the coupon, add the exact same coupon again and proceed to checkout, it doesnt work and the coupon is applied.
Re: Wrong Behavior Required & BasketValues Decorator
Post by aimeos » 30 Nov 2019, 18:46
Can you please check what's happening here when it doesn't work as expected?
https://github.com/aimeos/aimeos-core/b ... hp#L78-L97
