LanguageID in email
webshade
LanguageID in email
Post by webshade » 10 Dec 2019, 13:27
How can I turn off/hide the languageID in emails?
Re: LanguageID in email
Post by aimeos » 11 Dec 2019, 12:32
webshade
Post by webshade » 11 Dec 2019, 12:50
Isn't it available with typoscript? After an update I have to adapt it again...
Post by aimeos » 12 Dec 2019, 10:01
It's a translation you can change, maybe also via TS if you get the new lines right in TS:
https://aimeos.org/docs/TYPO3/Overwrite_translations
webshade
Post by webshade » 12 Dec 2019, 11:14
I only want to hide that field, not translate it.
Post by aimeos » 12 Dec 2019, 12:40
The address output is generated by printf() using a string with positional parameters (e.g. %1$s) where the address field data is inserted. Thus, you can change the string and remove the parameter for the language (i.e. %13$s in this case) by configuring a new translation string.
