Problems installing
pagliaso
Problems installing
Post by pagliaso » 29 Jan 2020, 14:09
I am trying to evaluate Aimeos on an existing Typo3 installation in version 9.5.13
I am installing Aimeos using composer. If finish with no error, but when I try to complete the installation from the Extension manager of the backend, I get an error:
#0 /home/domain/t3kit/ext/ai-typo3/lib/custom/src/MShop/Customer/Manager/Group/Typo3.php(289): Aimeos\MW\DB\Statement\DBAL\Simple->bind(1, 0, 2)
With other lines more.
I am stuck at the moment.
Many thanks in advance for your help, and kind regards from Spain
Re: Problems installing
Post by aimeos » 29 Jan 2020, 17:51
Can you post the stack trace of your error? Seems a bit arkward, can you run the update script in the Extension Manager or is the error from there?
pagliaso
Post by pagliaso » 29 Jan 2020, 22:01
Many thanks for your prompt reply.
This is the complete error I get when I run the update script from the Extension Manage:
Binding parameters is not available for simple statements
#0 /home/domain/public_html/t3kit/ext/ai-typo3/lib/custom/src/MShop/Customer/Manager/Group/Typo3.php(289): Aimeos\MW\DB\Statement\DBAL\Simple->bind(1, 0, 2)
#1 /home/domain/public_html/t3kit/vendor/aimeos/aimeos-core/lib/mshoplib/src/MShop/Common/Manager/Decorator/Base.php(187): Aimeos\MShop\Customer\Manager\Group\Typo3->saveItem(Object(Aimeos\MShop\Customer\Item\Group\Standard), true)
#2 /home/domain/public_html/t3kit/vendor/aimeos/aimeos-core/lib/mshoplib/setup/MShopAddCodeData.php(70): Aimeos\MShop\Common\Manager\Decorator\Base->saveItem(Object(Aimeos\MShop\Customer\Item\Group\Standard))
#3 /home/domain/public_html/t3kit/vendor/aimeos/aimeos-core/lib/mshoplib/setup/default/MShopAddCodeDataDefault.php(45): Aimeos\MW\Setup\Task\MShopAddCodeData->process(Array)
#4 /home/domain/public_html/t3kit/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php(114): Aimeos\MW\Setup\Task\MShopAddCodeDataDefault->migrate()
#5 /home/domain/public_html/t3kit/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php(110): Aimeos\MW\Setup\Manager\Multiple->migrateTasks(Array, Array)
#6 /home/domain/public_html/t3kit/vendor/aimeos/aimeos-core/lib/mwlib/src/MW/Setup/Manager/Multiple.php(82): Aimeos\MW\Setup\Manager\Multiple->migrateTasks(Array)
#7 /home/domain/public_html/t3kit/web/typo3conf/ext/aimeos/Classes/Setup.php(85): Aimeos\MW\Setup\Manager\Multiple->migrate()
#8 /home/domain/public_html/t3kit/var/transient/ext_updatef94c694d9e7de8af8bab7136c7b9badf.php(56): Aimeos\Aimeos\Setup::execute()
#9 /home/domain/public_html/t3kit/web/typo3/sysext/extensionmanager/Classes/Utility/UpdateScriptUtility.php(41): ext_updatef94c694d9e7de8af8bab7136c7b9badf->main()
#10 /home/domain/public_html/t3kit/web/typo3/sysext/extensionmanager/Classes/Controller/UpdateScriptController.php(52): TYPO3\CMS\Extensionmanager\Utility\UpdateScriptUtility->executeUpdateIfNeeded('aimeos')
#11 /home/domain/public_html/t3kit/web/typo3/sysext/extbase/Classes/Mvc/Controller/ActionController.php(318): TYPO3\CMS\Extensionmanager\Controller\UpdateScriptController->showAction('aimeos')
#12 /home/domain/public_html/t3kit/web/typo3/sysext/extbase/Classes/Mvc/Controller/ActionController.php(167): TYPO3\CMS\Extbase\Mvc\Controller\ActionController->callActionMethod()
#13 /home/domain/public_html/t3kit/web/typo3/sysext/extbase/Classes/Mvc/Dispatcher.php(73): TYPO3\CMS\Extbase\Mvc\Controller\ActionController->processRequest(Object(TYPO3\CMS\Extbase\Mvc\Web\Request), Object(TYPO3\CMS\Extbase\Mvc\Web\Response))
#14 /home/domain/public_html/t3kit/web/typo3/sysext/extbase/Classes/Mvc/Web/BackendRequestHandler.php(35): TYPO3\CMS\Extbase\Mvc\Dispatcher->dispatch(Object(TYPO3\CMS\Extbase\Mvc\Web\Request), Object(TYPO3\CMS\Extbase\Mvc\Web\Response))
#15 /home/domain/public_html/t3kit/web/typo3/sysext/extbase/Classes/Core/Bootstrap.php(217): TYPO3\CMS\Extbase\Mvc\Web\BackendRequestHandler->handleRequest()
#16 [internal function]: TYPO3\CMS\Extbase\Core\Bootstrap->handleBackendRequest(Object(TYPO3\CMS\Core\Http\ServerRequest))
#17 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Http/RouteDispatcher.php(87): call_user_func_array(Array, Array)
#18 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Http/RequestHandler.php(73): TYPO3\CMS\Backend\Http\RouteDispatcher->dispatch(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(TYPO3\CMS\Core\Http\Response))
#19 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Middleware/SiteResolver.php(59): TYPO3\CMS\Backend\Http\RequestHandler->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#20 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Backend\Middleware\SiteResolver->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(TYPO3\CMS\Backend\Http\RequestHandler))
#21 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Middleware/AdditionalResponseHeaders.php(39): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#22 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Backend\Middleware\AdditionalResponseHeaders->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(class@anonymous))
#23 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Middleware/OutputCompression.php(45): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#24 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Backend\Middleware\OutputCompression->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(class@anonymous))
#25 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Middleware/LegacyBackendTemplateInitialization.php(42): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#26 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Backend\Middleware\LegacyBackendTemplateInitialization->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(class@anonymous))
#27 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Middleware/BackendUserAuthenticator.php(70): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#28 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Backend\Middleware\BackendUserAuthenticator->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(class@anonymous))
#29 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Middleware/BackendRouteInitialization.php(72): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#30 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Backend\Middleware\BackendRouteInitialization->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(class@anonymous))
#31 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Middleware/ForcedHttpsBackendRedirector.php(53): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#32 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Backend\Middleware\ForcedHttpsBackendRedirector->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(class@anonymous))
#33 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Middleware/LockedBackendGuard.php(71): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#34 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Backend\Middleware\LockedBackendGuard->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(class@anonymous))
#35 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Middleware/NormalizedParamsAttribute.php(58): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#36 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(138): TYPO3\CMS\Core\Middleware\NormalizedParamsAttribute->process(Object(TYPO3\CMS\Core\Http\ServerRequest), Object(class@anonymous))
#37 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/MiddlewareDispatcher.php(67): class@anonymous->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#38 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/AbstractApplication.php(108): TYPO3\CMS\Core\Http\MiddlewareDispatcher->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#39 /home/domain/public_html/t3kit/web/typo3/sysext/backend/Classes/Http/Application.php(68): TYPO3\CMS\Core\Http\AbstractApplication->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#40 /home/domain/public_html/t3kit/web/typo3/sysext/core/Classes/Http/AbstractApplication.php(120): TYPO3\CMS\Backend\Http\Application->handle(Object(TYPO3\CMS\Core\Http\ServerRequest))
#41 /home/domain/public_html/t3kit/web/typo3/index.php(24): TYPO3\CMS\Core\Http\AbstractApplication->run()
#42 /home/domain/public_html/t3kit/web/typo3/index.php(25): {closure}()
#43 {main}
Many thanks and kind regards
Post by aimeos » 30 Jan 2020, 09:38
Which Aimeos version are you using? Do you use composer or the TER package?
pagliaso
Post by pagliaso » 30 Jan 2020, 10:22
Hi thanks,
I used composer as per instructions on extensions.typo3.org, and I see that on the Extension Manager appears as 20.1.1
Many thanks and kind regards,
Alb
pagliaso
Post by pagliaso » 30 Jan 2020, 10:24
Hi again,
I don't think it is related, but during installation, it also complains about a directory Extensions missing in aimeos/private/resources/ but I created this manually and didn't receive any other complaint on this.
Thanks and kind regards,
Alb
Post by aimeos » 30 Jan 2020, 10:41
Please use this documentation for reference when using the composer package:
https://github.com/aimeos/aimeos-typo3#composer
Make also sure you install 19.10 because 20.01 is the current beta and shouldn't be used for projects yet.
pagliaso
Post by pagliaso » 30 Jan 2020, 22:48
Many thanks for your help.
I have installed 19.10 and it is all good now.
Alb
