Catalog root node limit of 1000?
boettner
Post by boettner » 29 Jan 2020, 15:38
our root catalog node displays all available products. I saw there is a slice limit of 1000 in the DB request. Is there a possibility to expand that limit so that all available products could be browsed by pagination only if one wishes to do so?
Best
Robert.
Re: Catalog root node limit of 1000?
Post by aimeos » 29 Jan 2020, 17:42
You can use these two configuration options to tweak the number of pages and the number of products per page:
- https://aimeos.org/docs/Configuration/C ... ists/pages
- https://aimeos.org/docs/Configuration/C ... lists/size
boettner
Post by boettner » 30 Jan 2020, 07:05
We are still using the defaults which would mean a maximum of 4800 products. Why do we get 1000 for listProductTotal in client/html/templates/catalog/lists/body-standard.php?
Maybe because we are on 18.10 and client/html/catalog/lists/pages is available as of 19.04 only?
Post by aimeos » 30 Jan 2020, 09:40
The count SQL statements limits to 1000 rows:
https://github.com/aimeos/aimeos-core/b ... #L369-L380
Maybe we should increase it to 10000. Can you make a pull request?
