Trigger for User creation
cyrotek
Post by cyrotek » 20 Feb 2020, 09:17
right now the user is being created once the user hits buy now, wether its paid or not. Is it possible to have the user created once the payment is done or the status is not open at least?
A hint in the right - file - direction, would be appreciated.
Regards
Re: Trigger for User creation
Post by aimeos » 21 Feb 2020, 07:46
The customer account is created immediately to assign the customer ID to the order:
https://github.com/aimeos/ai-client-htm ... d.php#L229
You could remove the subpart by configuration and add the code to the checkout confirm component.
cyrotek
Post by cyrotek » 04 Mar 2020, 10:51
Thanks for the feedback on that.
Do you have a hint on how I would remove the subpart by configuration and add it to the confirm page? I am a bit clueless.
Post by aimeos » 05 Mar 2020, 14:45
Remove "account" from that configuration:
https://aimeos.org/docs/Configuration/C ... d/subparts
Then create a new subpart for the checkout confirm component:
https://aimeos.org/docs/Developers/Html ... w_subparts
Finally, add it to that configuration:
