No item found for conditions: Array ( [locale.site.code] => default )
I'm setup Aimeos 19.10.5 on TYPO 9.5.3.
I followed all the steps, and I executed the update script of the Aimeos extension in the extension manager
but I get this error :
I installed and uninstalled the extension several times but still the same problem.
thanks in advance for the support
(1/1) Aimeos\MShop\Exception
Re: No item found for conditions: Array ( [locale.site.code] => default )
I fixed my problem with this solution :
1. I changed the fe_users table Engine, from to
2. and then run the SQL again :
3. executed again the update script of the Aimeos extension in the extension manager
MyISAM Code: Select all
InnoDB2. and then run the SQL again :
ALTER TABLE fe_users_address
ADD CONSTRAINT fk_t3feuad_pid
FOREIGN KEY (parentid)
REFERENCES fe_users (uid) ON UPDATE CASCADE ON DELETE CASCADE
