Product options with checkbox field
cnoelker
Post by cnoelker » 06 May 2020, 12:24
is there a way to configure a custom options field as a checkbox on the product detail page?
On the demo page: http://typo3.demo.aimeos.org/demo/detai ... article/0/
there is a dropdown, a text, an integer and a date field. How can I create a checkbox?
Claudia
Re: Product options with checkbox field
Post by aimeos » 08 May 2020, 08:15
Use "client/html/catalog/attribute/type/<code>" -> "input"
Code: https://github.com/aimeos/ai-client-htm ... #L103-L125
cnoelker
Post by cnoelker » 09 May 2020, 10:03
thank you. I checked the code. In case of a custom attribute, the lines starting from 156 are relevant, not the ones which you highlighted.
So, only three types are accepted, currently: price, date and text (which is default).
I added a case for the checkbox:
<?php break; case 'checkbox': ?>
<input class="form-control" type="checkbox" name="<?= $enc->attr( $this->formparam( array( 'b_prod', 0, 'attrcustid', $id ) ) ); ?>" />
Works like a charm. :)
Claudia
