Second Site: Order IDs
cnoelker
Post by cnoelker » 12 Jun 2020, 11:22
Hi again,
another question raising up when configuring a second site:
Both orders are stored in the mshop_order table and they are both using the same ID for creating a unique order ID.
E.g.
Order ID 12001 -> Site 1
Order ID 12002 -> Site 2
Order ID 12003 -> Site 1
Is there a way to prevent this and to provide separate counting schemas for the sites?
E.g.
Order ID 50001 -> Site 2
Order ID 12002 -> Site 1
Claudia
Re: Second Site: Order IDs
Post by aimeos » 13 Jun 2020, 12:09
No way if you use a shared database for both sites because it's an AUTO_INCREMENT column
cnoelker
Post by cnoelker » 13 Jun 2020, 12:14
I suspected this, too. Just wanted to be sure that I didn't overlook something.
