Show entire category tree starting from root
loeffe1
Post by loeffe1 » 18 Jun 2020, 15:59
I have a problem with the category tree.
I have a bunch of nested categories like this:
Categories
|_ Root
|_ Category 1
|_ Category 2
|_ Category 2-1
|_ Category 2-2
|_ Category 2-3
|_ Category 3
If I set the tree startid to the id of Category 2, all subcategories of that category will be shown as expected.
However, if I set the startid to the Root category only the first subcategory (Category 1 ) will be shown.
What am I doing wrong?
Re: Show entire category tree starting from root
Post by aimeos » 19 Jun 2020, 07:50
Are all other first level categories activated (look at the status of each category in the admin backend)
loeffe1
Post by loeffe1 » 19 Jun 2020, 09:14
Yes, status is set to enabled for all of them.
loeffe1
Post by loeffe1 » 01 Jul 2020, 08:48
I reimported my categories and now all of them are displayed. However now I am running into a new problem where as first level the root category is shown, so my menu will look like this
Root
|-- Category 1
|-- Category 2
|-- Category 3
If setting the startid to the id of the root category, the root category shouldn't be shown but instead all categories within root.
Post by aimeos » 01 Jul 2020, 09:05
To hide the root node, change your template from:
'nodes' => [$this->treeCatalogTree],
to
'nodes' => $this->treeCatalogTree->getChildren(),
loeffe1
Post by loeffe1 » 07 Jul 2020, 11:01
Thanks, this will surely come in handy soon or later. For this current project it made more sense to use a DataProcessor to fetch the info from the mshop_catalog table. The category menu I was displaying needed to be accessible from anywhere on the page, not just from pages within /shop. So I wasn't able to use the catalog tree action because I would be missing the /shop part in my urls for other pages .
